BT.com
Wishlist
HGST 1TB Touro Mobile MX3 USB 3.0 2.5" Portable Hard Drive
Delivery
Standard Due date unavailable
Touro Mobile: Portable storage for all your files.
Touro™ Mobile external drive provides portable storage for all your photos, movies, music and documents. With plug and play simplicity, Touro Mobile comes with all the quality and reliability you expect from Hitachi.
Hitachi Global Storage Technologies (Hitachi GST) develops advanced hard disk drives, enterprise-class solid state drives, and innovative external storage solutions and services to store, preserve and manage the world's most valued data.
  • Portable storage for all your digital files
  • Smooth, textured body for solid good looks
  • Preformatted for PCs, easily reformatted for Macs
  • Fast USB 3.0 Interface
  • USB powered
  • 2.5 inch External Hard Disk Drive
  • Interface: USB 3.0 compliant, USB 2.0 compatible
  • Dimensions: Product: 80mm (W) x 126mm (H) x 15mm (D)
  • System Requirements: Windows: Computer system running with Windows® XP, Windows® Vista, or Windows 7TM and an available USB 2.0 or 3.0 port, Macintosh: Computer system running with Mac OS® 10.5 or newer and an available USB port
  • 2 year warranty
Includes
  • Touro Mobile external hard drive
  • USB 3.0 cable
  • Quick Start Guide
HGST Touro Mobile MX3 HTOLMX3EA10001ABB - hard drive - 1 TB - USB 3.0
Hard drive - external (portable)
1 TB
2.5"
USB 3.0
Spindle Speed
5400 rpm
Bus Powered by USB
Power Source
USB bus
Enclosure Colour
8 cm x 12.6 cm x 1.5 cm
EMEA
2 years warranty
1 TB
2.5"
USB 3.0
Bus Powered by USB
8 cm
12.6 cm
1.5 cm
Performance
Spindle Speed
5400 rpm
Expansion & Connectivity
1 x USB 3.0
Compatible Bay
2.5"
Power Source
USB bus
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
1 x USB cable
Enclosure Colour
EMEA
Accessories
C2G 2m USB 3.0 A Male to Micro B Male Cable
Quicklinx: 7GNS | In Stock
£7.33
Resources
The following resources are available for the HGST 1TB Touro Mobile MX3 USB 3.0 2.5" Portable Hard Drive
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Slick unit !
Reviewed by Bhav on 27/01/2013
I bought this unit together with another drive as my first purchase with BT. No complaints what so ever with the service I got.
This drive is so slick ! Its quiet, fast and fantastic value for money. I bought this to backup my software from laptop but tried it on my smart TV as a PVR drive and its fantastic ! It matches the finish of my TV and I have it attached by 'Velcro' on the back of the TV. It looks as its made for it !
I highly recommend this drive.
5* Fantastic, Fast and Fully Reliable
Reviewed by Morrison Frew on 07/12/2012
Hitachi has always been one of my favourite drives and this fully lives up to expectation. I have used this for a few months now and it continues to impress with its speed of operation and its reliability. It is USB 3.0 but it works really fast on the USB 2.0 port. Although it is USB powered I have had no problems with the normal computer inputs. Some portable drives need extra power but this does not. If you are using an extension hub with other devices attached then you may need to use a powered hub since the USB input needs to have enough power to operate the drive. I can not understand why BT has reduced the price - it was worth the original price so of how much more value is it now. After my initial experience with it I bought another two. You will not be disappointed with it.
Scroll to top
