BT.com
Wishlist
Hercules WAE Outdoor BTP04 - Wireless Outdoor Bluetooth Speaker
Hercules WAE Outdoor BTP04 -...
£72.24
£72.24
Add to wishlist
Delivery
Standard Due date unavailable
WATER- AND DUST-RESISTANT
Because outdoor sports and adventures are even more fun with a soundtrack of your favorite music... The Outdoor BTP04 lets all sports fans and adventure-seekers stream music from their smartphone featuring the Bluetooth® wireless technology, anywhere outdoors. IP64-certified, with the BTP04 you don't need to worry about water sprays or snow, and it even provides total protection against dust and sand as well. It's perfect for amateur or pro skiers and snowboarders, BMX riders, mountain bikers, hikers, Parkour fans and more!
WIRELESS
The BTP04 features Bluetooth® wireless technology, providing a range of up to 10 meters (depending on your environment and listening conditions). Thanks to its built-in mic, it also includes a hands-free calling function: take a call, and then pick up listening to your music right where you left off. It couldn't be easier!
ACCESSORIES
The BTP04 includes a USB cable, snap hook, wrist-strap and protective pouch, and is also available in a version with accessories that will let you enjoy the ultimate in sports adventures with your favorite music! A car cigarette-lighter charger, bike mount, suction cup mount and backpack attachment clip are also included in a special WAE OUTDOOR BTP04 ADVENTURE PACK (search 8QX5 in the searchbox for this product).
BATTERY LIFE
The BTP04 is powered by a battery providing more than 14 hours of playback time at 80% volume. Your music will follow you everywhere, throughout a full day of sporting fun!
MINI-SIZED and IMPACT-RESISTANT
At just 280 grams and 15 cm wide, it's the perfect companion for all your sports activities. Its rubber end-pieces and double protective grille provide enhanced impact resistance. Despite its small size, it provides accurate sound quality. For even more output power, you can connect multiple BTP04 speakers to one another for joint playback.
MUSIC REMOTE
More comprehensive than any remote control, the WAE application enables you to manage your OUTDOOR BTP04 easily. Listening to music becomes nothing but pure pleasure. Every time this application is launched on AndroidTM, it automatically activates the smartphone's Bluetooth® connection, which then automatically connects to the speaker.
Hercules WAE Outdoor BTP04 - speaker - for portable use - wireless
Speaker - for portable use
Protection
Shockproof, waterproof
Speaker Type
Active
Nominal Output Power (Total)
4 Watt
Audio System Max Output Power
8 Watt
Frequency Response
130 - 20000 Hz
Amplifier
Integrated
Bluetooth
Speaker Details
Speaker - stereo - 2 x 2 Watt - 130 - 20000 Hz - active
Power Options
USB charging
Speaker battery rechargeable - Lithium Ion
15.1 cm x 6.1 cm x 6.1 cm
280 g
Hands-Free Function
Protection
Speaker System
Speaker Type
Active
4 Watt
Max (RMS) Output Power (Total)
8 Watt
Frequency Response
130 - 20000 Hz
Magnetic Shield
Amplifier
Integrated
Bluetooth 2.1 EDR
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP)
Speaker System Details
Speaker Details
Driver Details
Speaker: 2 x full-range driver , Speaker: Passive Radiator
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
Audio cable, wrist strap, USB charging cable
Power Source
Options
USB charging
Rechargeable - Lithium Ion
1200 mAh
Run Time (Up To)
14 hour(s)
15.1 cm
6.1 cm
6.1 cm
280 g
Other bundles
Hercules WAE Outdoor BTP04 - Wireless Outdoor Bluetooth...
£72.24
Save on TP Link Smart Plug
Save £2.00
£96.21
Scroll to top
