BT.com
Wishlist
Hercules WAE Outdoor 04 Plus Pack Outdoor Speaker With Bike Mount and Backpack Clip
Hercules WAE Outdoor 04 Plus Pack...
£66.81
£66.81
Add to wishlist
Delivery
Standard Due date unavailable
Made for Riders!
  • Super-tough bike mount: designed to withstand intense vibrations.
  • Backpack attachment clip: specially created for extreme use
  • Clear, very powerful sound for optimal listening in outdoor conditions: single-unit 2.0 speaker + passive decompression driver.
  • IP66-certified: protected against powerful water jets, and totally protected against dust, sand and mud.
  • Shock-resistant: reinforced rubber end-pieces.
  • Standard-size screw thread, for secure attachment of the included accessories or any other standard attachment system.
  • Bluetooth® 3.0 A2DP wireless technology: compatible with Bluetooth® devices.
  • More than 12 hours of battery life.
  • Lets you connect two Bluetooth® audio sources at the same time, and switch from one to the other quickly and easily.
  • Handy control buttons: volume + and -, next and previous tracks, pause and play.
  • On/off switch and auxiliary line input.
  • USB charging cable included: compatible with 5 V micro-USB chargers.
  • Secure tether hook for wrist strap.
  • Custom Android and iOS app for smartphones.
Hercules WAE Outdoor 04Plus pack - speaker - for portable use - wireless
Speaker - portable
Protection
Shockproof, dustproof, waterproof, sandproof
15.1 cm x 6.1 cm x 6.1 cm
280 g
Speaker Type
Active
Nominal Output Power
5 Watt
Max Output Power
10 Watt
Frequency Response
130 - 20000 Hz
Audio Amplifier
Integrated
Connectivity Interfaces
Bluetooth
Speaker Details
Speaker - stereo - 2 x 2.5 Watt - 130 - 20000 Hz - active
Power Options
USB charging
Speaker battery rechargeable - Lithium Ion
Speaker - for portable use
Protection
15.1 cm
6.1 cm
6.1 cm
280 g
Speaker System
Speaker Type
Active
5 Watt
Max Output Power
10 Watt
Frequency Response
130 - 20000 Hz
Magnetic Shield
Audio Amplifier
Integrated
Bluetooth 3.0
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP)
Controls
Power on/off, volume, play/pause, next track, previous track
Speaker System Details
Speaker Details
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
Wrist strap, backpack clip, USB charging cable, bike mount
Power Source
Options
USB charging
1500 mAh
Run Time (Up To)
12 hour(s)
Scroll to top
