BT.com
Wishlist
Hercules WAE - BT03 - wireless - 12 Watt - White/Green
Delivery
Standard Due date unavailable
Wireless Bluetooth Speaker
SIMPLICITY
Play the music stored on all your devices featuring the Bluetooth® wireless technology (smartphone, tablet or computer). It's simple, compact... and indispensable! Activate your smartphone's Bluetooth® feature, and the BT03 will connect easily.
WIRELESS
The BT03 speaker uses Bluetooth® technology, offering a 15 metre range (50'). You can take it with you everywhere inside your home - the music never stops.
COMPACT
Boasting a very compact size (only 23.5 cm long), the BT03 enables you to take your music with you everywhere inside your home - ideal for close-range, instant and ultra-simple listening.
STEREO
In spite of its small size, the 2.0 single-unit BT03 system offers ample power and a balanced audio rendition quality: true-to-life bass and realistic medium and treble.
MUSIC REMOTE
More comprehensive than any remote control, the WAE application enables you to manage your BT03 easily. Listening to music becomes nothing but pure pleasure. Every time this application is launched on AndroidTM, it automatically activates the smartphone's Bluetooth® connection, which then automatically connects to the speaker.
AUX input
The speaker features a 3.5 mm mini-jack input, enabling you to connect it to your MP3 player or any other music device.
  • Bluetooth® EDR (A2DP) 2.0 audio system with Bluetooth® wireless technology
  • Original and trendy design - Compact size to bring your music everywhere
  • Two wide-range active drivers
  • Dual bass ports located behind the grille
  • Lacquered finish
  • Embossed metal grille protecting the drivers
  • Grip featuring a rubber insert, for comfortable transport
  • Volume adjustment buttons on front of unit
  • Bluetooth® pairing button on front of unit
  • ON/OFF switch
  • Auxiliary line input
  • Included application to control the speaker with your smartphone or tablet
Technical specifications
Total power output: 2 x 6 W RMS
Peak power: 24 W
Frequency response: 80 Hz - 20,000 Hz
Satellite measurements: 12 (H) x 23.5 (W) x 10.5 (D) cm
Built-in power supply
Satellites with magnetic shielding for an interference-free environment
RoHS-standard compliant product
Box contents
1 single-unit Bluetooth®audio system
1 power cord
Warranty certificate and user manual
Hercules Wireless Audio Experience BT03 - speaker - for portable use - wireless
Speaker - portable
23.5 cm x 10.5 cm x 12 cm
Speaker Type
Active
Nominal Output Power (Total)
12 Watt
Audio System Max Output Power
24 Watt
Frequency Response
80 - 20000 Hz
Audio Amplifier
Integrated
Connectivity Interfaces
Bluetooth
Speaker Details
Speaker 6 Watt - active
White, green
Speaker - for portable use
23.5 cm
10.5 cm
12 cm
Enclosure Colour
White, green
Speaker System
Speaker Type
Active
12 Watt
Max (RMS) Output Power (Total)
24 Watt
Frequency Response
80 - 20000 Hz
Magnetic Shield
Audio Amplifier
Integrated
Bluetooth 2.0 EDR
Bluetooth Profiles
Advanced Audio Distribution Profile (A2DP)
Controls
Power on/off, volume
Speaker System Details
Speaker Details
Driver Details
2 x full-range driver
Connector Type
Audio input
Power Source
AC power adapter
Scroll to top
