BT.com
Wishlist
Hercules DJ Control MP3 LE
Delivery
Standard Due date unavailable
2 decks to mix 2 music tracks
- Mix 2 music tracks with the DJControl MP3 LE's comprehensive controls
- 2 jog wheels let you navigate within the track on each deck
- 1 crossfader and 2 volume faders let you mix 2 tracks
Simplified DJing operations
User-friendly automations for beginners, via DJUCEDTM 18o
- Auto Cue: place a cue point on the first beat of a track
- Instant synch: 1 button sets the beat, if you don't want to adjust the pitch manually
- Easy loops: loops can automatically fit on the beat's length
Easily add your own personal touch to music files
- Equalize tracks to enhance their sound
- Add effects to tracks, for your own personal touch
- Save your mixes as your own music files
Perfect for mobile use
- Compact DJ mixing control surface
- DJUCEDTM 18o DJ software included: a great interface on both compact and large displays
Technical specifications
USB-powered DJ controller
2 decks + mixer controls
Includes DJUCEDTM 18° DJ software with optimized MIDI mapping
Weight < 2.2 lbs / 1 kg
Box contents
Hercules DJControl MP3 LE
USB cable
CD with DJUCEDTM 18° DJ software
Printed installation guide
Minimum configuration
Computer CPU: 1.5 GHz or faster
2 GB of RAM or more
Powered USB port
100 MB available disk space
CD/DVD-ROM drive
Internet access
Sound card with 1 or 2 stereo outputs
Stereo amplified speakers and/or headphones
Operating system (32/64-bit)
MS Windows® XP/Vista/7/8
Mac OS® 10.6/10.7/10.8
Mixing board
Device to which a variety of sound sources can be connected and mixed together: the mix is adjusted using a cross later, volume faders and several EQ knobs.
Mixing / Mix
Mixing is the art of blending together several pieces of music to create an overall sound. The music produced by this act is referred to as a mix.
DJ
Abbreviation of Disc Jockey: a person who selects and plays music at a party.
Hercules DJ Control MP3 LE - DJ controller - 2-channel
26.5 cm - 19 cm
1 kg
DJ controller
Mixer
Channels Qty (for SD)
2-channel
Control Types
Knobs, faders, jog wheels
Software Included
DJUCED 18°
MS Windows XP, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8
Headphone source select switch, bass & treble control, USB bus powered, illuminated controls
Channel Description
EQ Band Qty
3
Connector Type
1 x USB (4 PIN USB Type B) - rear
USB cable
26.5 cm
19 cm
1 kg
Scroll to top
