BT.com
Wishlist
Hauppauge USB Live 2 PC & Laptop USB Video Capture Kit
Hauppauge USB Live 2 PC & Laptop...
£30.81
£30.81
Add to wishlist
Delivery
Standard Due date unavailable
Watch, capture or record live video from your VCR, camcorder or video camera! USB-Live connects to any S-Video or composite video source and plugs into your PC or laptop's USB port. USB-Live's video digitizer turns your analog video into digital video, and then sends 30 digital images per second over the USB (1.1 or 2.0) bus.
Spice up your multimedia presentations! Create digital movies in the Microsoft AVI file format with Hauppauge's WinTV Capture application. The included Ulead DVD MovieFactory allows you to edit and author DVDs, VideoCDs and S-VCDs.
Creative Webmasters can incorporate still frame video highlights or motion video clips on their web sites!
With THE exclusive WinTV SnapShot application, you can quickly save video images! Capture 24-bit still video still images in TIFF, JPEG, BMP in color or black/white. It is also great for web design.
Hauppauge WinTV USB-Live2 - video capture adapter - USB 2.0
Video capture adapter
Interface Type
USB 2.0
English, German, French
Video Input
S-video input, composite video input
Analogue Video Format
NTSC, PAL
Video Compression Format
YUV 4:2:2
Digital Video Format
AVI
Digital Video Capture Resolution
720 x 480, 720 x 576
Audio Input Support
Standard
Built-in LED lights
Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Vista
Microsoft Certification
Certified for Windows Vista
2 years warranty
Interface Type
USB 2.0
Video
Interface Type
NTSC, PAL
YUV 4:2:2
AVI
Image Recording Format
JPEG, BMP, TIFF
Audio Input Support
Standard
Built-in LED lights
1 x display / video - S-video input - on cable , 1 x display / video - composite video input - RCA - on cable
1 x USB 2.0 - 4 pin USB Type A
1 x A/V cable - external - 1 cm , 1 x USB cable - 50 cm
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
Software Included
Ulead DVD MovieFactory, WinTV 7
Additional Requirements
CD-ROM, USB port
System Requirements Details
Windows XP/Vista/7 - Pentium - 2 GHz
Scroll to top
