BT.com
Wishlist
Hauppauge myMUSIC WiFi Adapter for Android / Apple Devices
Hauppauge myMUSIC WiFi Adapter for...
£58.70
2 in stock
£58.70
Add to wishlist
Delivery
Standard 3-5 working days
Listen to your Apple and Android music in HD quality audio on your home entertainment system via Wi-Fi!
myMusic Wi-Fi is a pocket size device which allows you to listen to all your favourite iPhone, iPad, iPod and Android music albums, audio tracks, radio stations, Spotify, Deezer or Pandora music wirelessly on your home entertainment system.
myMusic Wi-Fi is easy to install. Just plug in the supplied audio cable into your stereo 3.5mm or RCA jack to your home entertainment system. You may also use an Optical S/PDIF connection for HD quality sound (cable not included). Connect the myMusic Wi-Fi to your phone wirelessly via Wifi and you're ready to start listening to your favourite Albums, tracks, Radio stations, Spotify, Deezer or Pandora music.
The ultra compact design connects directly wirelessly to your Apple and Android device and designed to be used at home. It also supports PCs and MAC that support Wifi.
myMusic Wi-Fi is small enough to sit next to your home entertainment system yet powerful enough to support Airplay and DLNA - giving you the freedom to listen to your Apple and Android music in high quality optical HD audio.
myMusic Wi-Fi multi-room audio support?
myMusic Wi-Fi supports Airplay and has the ability to play your music library simultaneously across several different speaker systems simultaneously, filling your home with Music using existing your speaker systems or docking stations (Aux required).
myMusic Wi-Fi lets you play all of your favourite iTunes music from your Apple devices over your home's existing Wi-Fi network in any room of your house as long as you have a speak with a 3.5mm jack or an optical audio input.
Hauppauge MyMusic Wi-Fi - wireless audio receiver
Wireless audio receiver
Wireless Interface
Wi-Fi
Wireless Interface
IEEE 802.11b/g/n
Audio line-out - mini-phone stereo 3.5 mm , SPDIF output - TOS Link
Scroll to top
