BT.com
Wishlist
Hauppauge myMusic-Bluetooth Adapter for Android / Apple Devices
Hauppauge myMusic-Bluetooth Adapter...
£28.96
£28.96
Add to wishlist
Delivery
Standard Due date unavailable
Listen to your favourite albums, audio tracks, radio stations, Spotify, Deezer or Pandora music wirelessly on your home and car entertainment system via Bluetooth!
The Play/Pause button on myMusic Bluetooth allows you to start and stop your music on your smart phone or tablet, wirelessly!
myMusic Bluetooth turns your home audio sound system into a wireless sound system.
myMusic Bluetooth is a portable wireless music device which allows you to listen to your iPhone, iPad, iPod and Android music wirelessly via Bluetooth on your home audio system. Connecting myMusic Bluetooth to your audio system is simple: just plug in the supplied audio cable into your stereo 3.5mm or RCA jack. Connect your Apple or Android phone or Tablet to myMusic Bluetooth wirelessly and start to listen to your favourite music wirelessly on your home entertainment system.
By connecting your Apple or Android device with myMusic Bluetooth and a home audio system, you'll enjoy better sound quality than you can get from your phone or tablets built-in speakers. Simply plug the myMusic Bluetooth receiver into your sound system using the included standard analogue RCA or 3.5 mm jacks, connect myMusic Bluetooth to your Apple or Android smart phone or tablet via 'tap-and-play' NFC or using the standard Bluetooth pairing method, and you will automatically pair with your sound system to your mobile device. myMusic Bluetooth gives you the freedom to listen to music in your home wirelessly!
The ultra compact design is small enough to be used in your car, yet has the audio quality you'll want to have with your home audio system.
myMusic Bluetooth is small enough to fit in your pocket yet powerful enough to give you the freedom to listen to your Apple and Android music on the move or at home.
myMusic Bluetooth is small enough to fit in your pocket yet powerful enough to give you the freedom to listen your Apple and Android music on the move or at home. It even works with your headphones allowing you to convert your headphones to wirelessly receive music via Bluetooth.
Hauppauge myMusic - Bluetooth wireless audio receiver
Integrated Components
Microphone
Wireless Interface
Bluetooth, NFC
Rechargeable
Run Time (Up To)
10 hours
Package Content
Audio cable, Bluetooth wireless audio receiver
5.2 cm x 5.2 cm x 1.3 cm
26 g
English
Microphone
Wireless Interface
Bluetooth 3.0, NFC
Bluetooth Profiles
Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Package Content
5.2 cm
5.2 cm
1.3 cm
26 g
English
Audio line-out - mini-phone stereo 3.5 mm
Rechargeable Battery
Rechargeable
240 mAh
Run Time (Up To)
10 hours
NFC for Bluetooth pairing
Scroll to top
