BT.com
Wishlist
Hauppauge Ministick
Hauppauge Ministick
Delivery
Standard Due date unavailable
WinTV-MiniStick is small in size but includes a powerful built-in digital TV receiver. Inside WinTV-MiniStick is the latest high sensitivity DVB-T receiver for great TV reception at home or when you travel. WinTV-MiniStick can be used with the included portable DVB-T antenna, or you can use a rooftop aerial for the best digital reception.
Watching digital TV on a PC or laptop has never been simpler: just plug WinTV-MiniStick into your computer's USB 2.0 port, connect a digital TV antenna or aerial, install the WinTV application and in minutes you're ready to watch and record Freeview digital TV on your computer screen!
WinTV v7 is a digital video recorder, too! Record digital TV programs to disk in their original digital quality and play them back to your PC screen at any time. Use the built-in TV scheduler to automatically record your favorites TV shows, on a daily, weekly or once only schedule. You can even play back videos without a WinTV being plugged into your laptop, so you can watch recorded TV programs when you travel!
Hauppauge WinTV MiniStick SE - digital TV tuner - USB 2.0
Digital TV tuner - DVB-T
Interface Type
USB 2.0
Video Input
USB 2.0
Digital Video Format
MPEG-2, DVB
Audio Input Support
Standard
Remote control, Electronic Program Guide (EPG)
Microsoft Windows 7
2 years warranty
Interface Type
USB 2.0
Video
Interface Type
USB 2.0
MPEG-2, DVB
Audio Input Support
Standard
1 x TV antenna - input
1 x USB 2.0 - 4 pin USB Type A
TV aerial, remote control
Microsoft Windows 7
Scroll to top
