BT.com
Wishlist
Hannspree HL225DNB 21.5" 1920x1080 5ms VGA DVI LED Monitor
Hannspree HL225DNB 21.5" 1920x1080...
£78.26
£78.26
Add to wishlist
Delivery
Standard Due date unavailable
Marketing description is not available.
HANNS.G HL225DNB - LED monitor - 21.5"
LED-backlit LCD monitor - 21.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
50.4 cm x 13 cm x 31 cm
3.2 kg
3 years warranty
Display Type
Diagonal Size
21.5"
Viewable Size
21.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 82 kHz
Horizontal Viewing Angle
+90 / -90
Vertical Viewing Angle
+65 / -65
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, input select, colour temperature
Game mode, Cinema Mode
3.2 kg
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
100 x 100 mm
Wall mountable, LED indicator
Stand
1 x VGA cable - 1.5 m
Power Consumption Stand by
0.5 Watt
Limited warranty - 3 years
5 °C
35 °C
20 - 70% (non-condensing)
Scroll to top
