BT.com
Wishlist
HannsG HX194DPB 19" 1280x1024 5ms VGA DVI LED Backlit Monitor
HannsG HX194DPB 19" 1280x1024 5ms...
£107.54
Old Aspect Ratio Format for Particular Program Applications
£107.54
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
This square display is designed for those that require the old aspect ratio format for particular program applications but demand modern performance.
HANNS.G HX194DPB - LED monitor - 19"
LED-backlit LCD monitor - 19"
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 75 Hz
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
40.709 cm x 17.8 cm x 40.693 cm
3 kg
UL, GS, CB, FCC, NRTL, TCO Displays 6.0, EPA 6.0
Display Type
Diagonal Size
19"
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 82 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
WLED
3 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI-D (HDCP) , Audio line-in
Mechanical
Tilt
Tilt Angle
20
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable - 1.5 m , 1 x audio cable - 1.5 m
23 Watt
Power Consumption Stand by
0.5 Watt
Other bundles
HannsG HX194DPB 19
HannsG HX194DPB 19" 1280x1024 5ms VGA DVI LED Backlit...
£107.54
Save on TP Link Smart Plug
Save £2.00
£131.51
Scroll to top
