BT.com
Wishlist
HannsG HU282PPS 28" (3840 x 2160) 4K Ultra HD Toughened Glass Monitor
HannsG HU282PPS 28" (3840 x 2160)...
£325.60
£325.60
Add to wishlist
Delivery
Standard 1-3 working days
Features:
  • 28" 16:9 LED Backlight Monitor
  • 4K*2K 3840 x 2160 Resolution
  • Toughened Glass - extreme rugged protection
  • 5ms Fast Response Time
  • Display port
  • HDMI x 2, DVI-D
  • Built-In Stereo Speakers
  • Tilt and Wall-Mountable (VESA)
  • Multi-Video Modes
  • ECO Friendly
The HU282PPS utilize high performance panels to deliver true ultra high-definition resolution images. UHD, also known as 4K, offers an incredible viewable display area with 4 times more work space than Full HD screens and over 8 milion pixels.
The HANNspree HU282PPS features a hardware interface with advanced connections to maximize the usability. It provides seamless connectivity with your PC and AV equipment with DP, DVI and 2 different HDMI ports.
The HU282PPS has twin built-in 3 W speakers that provide quality audio for a completely immersive home theater experience. Built-in speakers make it easy to catch up with family, friends and colleagues.
HANNS.G HU Series HU282PPS - LED monitor - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class B
Energy Consumption per Year
55 kWh
Power Consumption (On mode)
38 W
Aspect Ratio
Widescreen - 16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 at 60 Hz
Pixel Pitch
0.16 mm
Brightness
280 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, DVI-D, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
68.01 cm x 19.2 cm x 50.41 cm
7.2 kg
3 years warranty
Display Type
Energy Class
Class B
55 kWh
38 W
Diagonal Size
28"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.16 mm
Brightness
280 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
60 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
WLED
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Korean
HDCP, game mode, FPS Mode, RTS Mode
7.2 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
DisplayPort , DVI-D , 2 x HDMI , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
75 x 75 mm
1 x audio cable , 1 x DVI cable
38 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Limited warranty - 3 years
0 - 70%
Other bundles
HannsG HU282PPS 28
HannsG HU282PPS 28" (3840 x 2160) 4K Ultra HD Toughened...
£325.60
Save on TP Link Smart Plug
Save £2.00
£349.57
Scroll to top
