BT.com
Wishlist
HannsG HS243HPB 23.6" 1920x1080 7ms VGA HDMI IPS Monitor Speake
Delivery
Standard Due date unavailable
HannsG's HS Series of LED monitors feature HS-IPS Panel with Ultra-Wide viewing angles of 178° coupled with Full HD resolutions to deliver the very best visual display. Perfect for graphic heavy multimedia applications and gaming the HS monitors promise consistent, accurate color from all viewing angles without any blur and stable response times without data loss which ensures a truly high quality viewing experience.
HANNS.G HS Series HS243HPB - LED monitor - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
Energy Class
Class A
Energy Consumption per Year
33 kWh
Power Consumption (On mode)
22 W
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 80000000:1 (dynamic)
Response Time
7 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Screen Coating
Anti-glare
56.127 cm x 20.99 cm x 41.321 cm
Display Type
Energy Class
Class A
33 kWh
22 W
Diagonal Size
23.6"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
7 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 82 kHz
Horizontal Viewing Angle
+89 / -89
Vertical Viewing Angle
+89 / -89
Screen Coating
Anti-glare
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Spanish
HDCP
Audio
Speakers - stereo
Output Power / Channel
2 Watt
HDMI , VGA , 2 x audio line-in
Mechanical
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
Stand
1 x VGA cable - 1.5 m , 1 x audio cable - 1.5 m
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
10 - 90% (non-condensing)
Scroll to top
