BT.com
Wishlist
HannsG HP227DJB 21.5" 1920x1080 5ms VGA DVI LED Monitor
HannsG HP227DJB 21.5" 1920x1080 5ms...
£102.67
More than 50 in stock
£102.67
Add to wishlist
Delivery
Standard 1-3 working days
Marketing description is not available.
HANNS.G HP Series HP227DJB - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare
51.28 cm x 21.72 cm x 49.35 cm
3.81 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, CB
Display Type
Diagonal Size
21.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
WLED
HDCP
3.81 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
VGA , DVI-D , Audio line-in
Mechanical
Height, tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable - 1.5 m , 1 x audio cable - 1.5 m
TUV GS, CB
24 Watt
Power Consumption Stand by
0.5 Watt
ENERGY STAR Certified
5 °C
35 °C
20 - 85% (non-condensing)
Scroll to top
