BT.com
Wishlist
HannsG HE247DPB 23.6" 1920x1080 5ms VGA DVI LED Monitor
HannsG HE247DPB 23.6" 1920x1080 5ms...
£99.20
20 in stock
£99.20
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Thursday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Marketing description is not available.
HANNS.G HE247DPB - LED monitor - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 40000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
Black texture, glossy black
561 mm x 220 mm x 399 mm
4.5 kg
Environmental Standards
ENERGY STAR Qualified
MPR II, UL, BSMI, GOST, cUL, NEMKO, CB, CCC, PSB, FCC, RoHS
Display Type
Diagonal Size
23.6"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
24 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
OSD Languages
English, German, French, Italian, Polish, Russian, Spanish, Dutch, Japanese, Korean
4.5 kg
VGA
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable - 1.5 m
Power Supply
Internal
(50/60 Hz)
28 Watt
Power Consumption Stand by / Sleep
0.5 Watt
0.5 Watt
Power Consumption Sleep
0.5 Watt
Microsoft Windows 7
ENERGY STAR Certified
5 °C
35 °C
20 - 85% (non-condensing)
Scroll to top
