BT.com
Wishlist
HannsG HE225DPB 21.5" 1920x1080 Full HD VGA DVI LED Monitor
HannsG HE225DPB 21.5" 1920x1080...
£92.59
Built In Speakers!
£92.59
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Marketing description is not available.
Hannspree HE225DPB - LED monitor - 21.5"
LED-backlit LCD monitor - 21.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 40000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
51.28 cm x 18.5 cm x 36.74 cm
3.12 kg
Environmental Standards
ENERGY STAR Qualified
UL, GOST, cUL, CB, CCC, FCC
Display Type
Diagonal Size
21.5"
Viewable Size
21.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
HDCP
3.12 kg
Audio
Speakers - stereo
Output Power / Channel
1.5 Watt
DVI-D (HDCP) , VGA , Audio line-in
Mechanical
Tilt
Tilt Angle
-3/+17
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable - 1.5 m , 1 x audio cable - 1.5 m
24 Watt
Power Consumption Stand by / Sleep
1.5 Watt
0.5 Watt
Power Consumption Sleep
0.5 Watt
5 °C
35 °C
20 - 85% (non-condensing)
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Customer return - item has been used and shows signs of use. Item has 1 dead pixel.
Ref: 8PKC 035634
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£56.83
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
