BT.com
Wishlist
HannsG HE196APB 18.5" 1166x768 5ms VGA Monitor with Speakers
HannsG HE196APB 18.5" 1166x768 5ms...
£72.92
11 in stock
£72.92
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Marketing description is not available.
HANNS.G HE196APB - LED monitor - 18.5"
LED-backlit LCD monitor - 18.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
600:1 / 50000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
44.6 cm x 14.76 cm x 34.5 cm
2.3 kg
Display Type
Diagonal Size
18.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
1366 x 768 at 60 Hz
Pixel Pitch
0.3 mm
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
24 - 61 kHz
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Screen Coating
Anti-glare
Backlight Technology
WLED
OSD Languages
English, German, French, Italian, Portuguese, Russian, Spanish, Dutch, Korean
2.3 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
VGA , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+15
Flat Panel Mount Interface
75 x 75 mm
Wall mountable, K-lock security slot
1 x VGA cable - 1.5 m
Power Supply
Internal
AC 100 V (50/60 Hz)
20 Watt
Power Consumption Stand by
0.5 Watt
5 °C
35 °C
20 - 85% (non-condensing)
Scroll to top
