BT.com
Wishlist
HannsG Hanns.G HA191DPB 19" 1280 x 1024 5MS DVI-D VGA LCD Monitor with Speakers
Delivery
Standard Due date unavailable
Marketing description is not available.
HANNS.G HA191DPB - LCD monitor - 19"
LCD monitor - 19"
Stereo speakers
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 15000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
41 cm x 16 cm x 41.1 cm
4.1 kg
Environmental Standards
ENERGY STAR Qualified
TCO '03, UL, GOST, GS, CB, FCC, RoHS
3 years warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
19"
Built-in Devices
Stereo speakers
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
HDCP
4.1 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
DVI-D , Audio line-in , VGA
Mechanical
Tilt
Tilt Angle
20
Flat Panel Mount Interface
1 x VGA cable , 1 x audio cable
Power Supply
Internal
AC 120/230 V (50 - 60 Hz)
32 Watt
Power Consumption Stand by / Sleep
1 Watt
Included Software
Drivers & Utilities
Limited warranty - 3 years
5 °C
35 °C
20 - 85%
Scroll to top
