BT.com
Wishlist
HannsG 22" Height Adjustable LED Monitor
Delivery
Standard Due date unavailable
Marketing description is not available.
HANNS.G HP225DJB - LCD monitor - 22"
LCD monitor - 22"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 15000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Speakers
Integrated
Display Position Adjustments
Height, swivel, tilt
51.3 cm x 22.5 cm x 42.9 cm
4 kg
Environmental Standards
ENERGY STAR Qualified
GOST, DDC-2B, NEMKO, CB, CCC, TCO Displays 5.2
Display Type
LCD monitor / TFT active matrix
Diagonal Size
22"
Viewable Size
21.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Dutch, Japanese, Korean
HDCP
4 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI-D , Audio line-in
Mechanical
Tilt Angle
-1/+20
Swivel Angle
60
Height Adjustment
80 mm
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable ¦ 1 x audio cable
25 Watt
Power Consumption Stand by / Sleep
0.5 Watt
5 °C
35 °C
5 - 90%
Scroll to top
