BT.com
Wishlist
HannsG 19" Widescreen TFT Monitor
Delivery
Standard Due date unavailable
This exquisitely detailed masterwork offers incredible 700:1 contrast and stunning 300-hit brightness.
Highlights of the HannsG HW191D 19"widescreen monitor
Screen: 19" widescreen (1440 x 900)
Brightness: 300 cd/m2
Dynamic Contrast Ratio: 3000:1
Response time: 5ms
Connectivity: VGA
Integrated multimedia speakers
HANNS.G HW191D - LCD monitor - 19"
LCD monitor - 19"
Built-in Devices
Stereo speakers
Aspect Ratio
Widescreen - 16:10
Native Resolution
1440 x 900
Pixel Pitch
0.283 mm
Brightness
300 cd/m²
Contrast Ratio
700:1
Response Time
5 ms
Colour Support
16.2 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Black, silver
45.3 cm x 19.8 cm x 37.1 cm
4.7 kg
Environmental Standards
ENERGY STAR Qualified
TCO '03, UL, BSMI, cUL, GS, CB, CCC, FCC
3 years warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
19"
Built-in Devices
Stereo speakers
Aspect Ratio
Widescreen - 16:10
Native Resolution
1440 x 900
Pixel Pitch
0.283 mm
Brightness
300 cd/m²
Contrast Ratio
700:1
Colour Support
Response Time
5 ms
Horizontal Viewing Angle
150
Vertical Viewing Angle
135
Colour Temperature
9300K, 6500K
Controls & Adjustments
Colour temperature
OSD Languages
English, German, French, Italian, Spanish, Japanese
Black, silver
4.7 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
1 x audio line-in - mini-phone 3.5mm , 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x DVI-D - 24 pin digital DVI
Mechanical
Flat Panel Mount Interface
Power Supply
Internal
AC 120/230 V ( 50/60 Hz )
55 Watt
Limited warranty - replacement - 3 years - on-site
5 °C
35 °C
10 - 85%
Customer reviews
Write review Read all The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Great Monitor, Great Price
Reviewed by on 02/08/2006
A fantastic monitor at a great price. Is perfect for games and playing DVDs on. Arrived promptly with no dead pixels and a 3 year manufacturers warranty. NB: it doesn't come with a digital cable, so buy the BT one at the same time as the monitor to save on packaging.
5* HANNS G WIDESCREEN MONITOR
Reviewed by PETE BEARD on 08/08/2006
BRILLIANT MONITOR AT A FANTASTIC PRICE. ORDERED THE MONITOR APPROX 5PM WEDNESDAY AFTERNOON WAS TOLD MONITOR WOULD BE IN STOCK 2 TO 3 DAYS LATER IT ARRIVED FRIDAY MORNING 11AM EASY SETUP EVEN I COULD DO IT AND I AM A COMPUTER NOVICE WHEN IT COMES TO HARDWARE DISPLAY SUPERB ON VGA BUT OUT OF THIS WORLD ON DVI ONLY DOWN SIDE SPEAKERS TINNY BUT USE POWER SPEAKERS SO NO PROBS 10 OUT OF 10 BT BRILL SERVICE THANKS
5* Superb
Reviewed by Gazzza on 12/08/2006
Fantastic display, very sharp and fast response.Quick delivery as usual from BT..
Reviewed by A.W.Kent on 17/08/2006
Ordered this monitor 15/8/06 arrived next day. No dead pixels easy to setup good screen very happy with it. Speakers not good but use powered ones so o`k Excellent BT service as usual. Would recomend other people to by this monitor and at this price its a steal.
5* Fantastic monitor - great delivery time
Reviewed by Brian on 31/08/2006
This is simply the best monitor you can buy for your money! Looks fantastic (uncluttered front as the speakers are underneath and the access buttons on the side), beautiful display and flawless aesthetics! Ordered this on Wednesday afternnon, was with me by Thursday lunchtime - quite simply OUTSTANDING service from BT - now stop reading and PUT ONE IN YOUR BASKET!!!
5* EXCELLENT!
Reviewed by Mike S on 03/09/2006
This monitor is simply awesome. At the same price as an unbranded BTValue monitor of the same quality at 5:4, this 16:10 monitor is great value. Mine arrived with one dead pixel that was fixed simply by rubbing the pixel with my finger :D. No DVI cable, but those are cheap. Excellent buy.
5* Can't beat this monitor
Reviewed by Roy on 11/12/2008
I read loads of reviews and they were ALL 5* for this monitor. So, I bought one. To be honest, even 5* isn't high enough - the quality is amazing and it looks just great - unless you need really fast rise times don't pay any more!
5* I purchased two because of the price
Reviewed by Nokonium on 30/12/2008
One for a backup PC (I have a home network) and one for a budget new PC I was building. I have found no minus points for this monitor and will be swapping it with my my Samsung when I receive the higher spec. graphics card I have on order (driver & gaming problems). This monitor is exceptionally good value for money.
5* Very Good monitor
Reviewed by Wojciech on 06/01/2009
It is really great Monitor and was quite cheap,so why spend more many for other monitors when this one does the job,great.
5* HannsG 19" Widescreen TFT Monitor
Reviewed by MR L on 22/09/2006
I'll start off with the delivery ordered sunday night arrived wednesday morning. the monitor itself does not come with DVI cable so buy BT value one, as you can tell the difference in quality if only slightly. setup no dead pixels, this is way better than my 17 xiod crt, the image is massivly better, and playing games like Counterstrike in 1440 X 900 is a fest for the eyes, monitor is easy to setup, run at 60 hz as when running in 75 on the dvi cable and you reboot your machine it didnt seem to pick up the 75hz refresh rate properly, if you buy this baby before september 29 th you get a further £10 voucher online which you can use against your order from BT. all in all deliver+dvi cable+monitor = £126 quid beat that any where, simple answer you cant!!!
Scroll to top
