BT.com
Wishlist
Griffin Reversible USB to Lightning Cable 1.5m (5ft) - Grey
Delivery
Standard Due date unavailable
The re-engineered USB connector works in any USB-A port regardless of how it's plugged in. It's the easiest to connect USB plug ever.
Griffin's long-life braided cable jackets resist kinking, while anodized aluminum housings stabilize the Lightning connector and protect it from physical stresses. Finally, Griffin put the redesigned cable design through brutal bend testing and environmental testing. The result is a premium cable that's built for longer, more reliable life.
Engineered for long life, aircraft-grade aluminum connector housing prevent cable failure due to wear and stress. Non-kinking wear-resistant braided cable jacketing is color-matched to current iPhone, iPad and iPod touch colors. The reversible USB connector plugs in right the first time, every time.
Griffin Premium - Lightning cable - Lightning / USB - 1.5 m
Cable
Length
1.5 m
Connector
USB - male
Connector (Second End)
Lightning - male
Reversible A connector
Apple 12.9-inch iPad Pro; iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; 4; iPad with Retina display (4th generation); iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus; iPod nano (7G); iPod touch (5G, 6G)
Cable Type
Lightning cable - reversible A connector
Interface Supported
Lightning / USB
Jacket Material
Nylon
Length
1.5 m
Braided, aluminium connector housing
Grey
Connector
4 pin USB Type A - male
Apple Lightning - male
Apple 12.9-inch iPad Pro , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad mini 4 , Apple iPad with Retina display (4th generation) , Apple iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus , Apple iPod nano (7G) , Apple iPod touch (5G, 6G)
Scroll to top
