BT.com
Wishlist
Griffin GA38330 10 Bay MultiDock Charging Unit
Store, Sync and Charge up to 10 Devices at Once!
Delivery
Standard Due date unavailable
10 Bay MultiDock Charger for Smartphone/Tablet iOS & Android
MultiDock is a single, space-efficient charging station for storing, charging, and syncing 10, 20 or even 30 iPad tablets or other devices. Its footprint is minimal: only slightly larger than a laptop computer. But in that space, each MultiDock unit packs storage, charging, and syncing capability for 10 tablets. Stack 3 MultiDocks together to sync 30 tablets in the same amount of counter space, from a single host computer.
Ideal for education or businesses that require many devices to be charged in a secure space.
  • Space-efficient, securable charging and storage for iOS and Android Tablets, Smartphones and more
  • Locking front panel secures tablets while charging
  • Link up to three MultiDocks (30 charging slots) to a host computer
  • Internal circuit protection, self-resetting
  • Individual color-changing LEDs indicate charging and syncing status for each bay
Charge Sensor Technology
MultiDock uses Griffin's exclusive ChargeSensor technology to optimize charging. ChargeSensor automatically detects the charging characteristics of each connected device and supplies the charging rate - up to 10 watts (5 volts @ 2.1 amps) of charging power per bay - each device needs for fastest, most complete charging.
MultiDock Quick Charge
Connecting an iPad 4, iPad mini or other device that uses Apple's new Lightning charge/sync connector automatically activates MultiDock's Quick Charge Mode. MultiDock charges these newer devices at the fastest possible rate, even while syncing, thus ensuring that your devices will be fully charged and ready when you need them.
Wide Charging Slots
With MultiDock you won't have to remove your tablets from their cases: each MultiDock charging bay accommodates even bulky protective cases. At 1.25" wide, MultiDock's charging slots are the widest available. Individual color-changing LEDs indicate charging and syncing status for each bay
Secure Installation
MultiDock is designed for easily securing it on a table, desk, or countertop. Included hardware allows installations that stack up to three units in one space. Locking front panel secures tablets while charging.
MultiDock Stacking
MultiDock is capable of being stacked yet still using the same footprint size. Stack 3 MultiDocks together to sync 30 tablets in the same amount of counter space, from a single host computer.
Griffin MultiDock - iPad docking station
Intended for
Tablet
Product Material
Aluminium, steel, acrylic
38.3 cm x 32 cm x 32.3 cm
8.44 kg
Intended for
Tablet
Product Material
38.3 cm
32 cm
32.3 cm
8.44 kg
10 x USB - 4 PIN USB Type A
Synchronization function, connection via USB, lock, LED indicator, charge up to 10 devices
Scroll to top
