BT.com
Wishlist
Go Lamp Generic GO Lamp For NEC VT470/670 Projectors
Go Lamp Generic GO Lamp For NEC...
£157.86
5 in stock
£157.86
Add to wishlist
Delivery
Standard 3-5 working days
Marketing description is not available.
GO Lamps projector lamp
Projector lamp - NSH - 180 Watt
OEM Manufacturer Lamp Equivalent
NEC 50030763, VT75LPE
Bulb life cycle
2000 hour(s)
2 years warranty
NEC LT280, LT280G, LT380, LT380G, VT470, VT470G, VT470GK, VT670, VT670G, VT676, VT676G; MultiSync LT280, LT380, VT470, VT470G, VT670; ViewLight VT470J, VT670J, VT676J
Projector lamp
Lamp
NSH
180 Watt
Life Cycle
2000 hour(s)
NEC LT280, LT280G, LT380, LT380G, VT470, VT470G, VT470GK, VT670, VT670G, VT676, VT676G , NEC MultiSync LT280, LT380, VT470, VT470G, VT670 , NEC ViewLight VT470J, VT670J, VT676J
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Customer return - item has been used and shows signs of use. New bulb required.
Ref: 8PRG 033717
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£22.78
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
