BT.com
Wishlist
Go Lamp 60003224/NP21LP Lamp Module for NEC PA600X/PA550W/PA500U
Go Lamp 60003224/NP21LP Lamp Module...
£248.52
£248.52
Add to wishlist
Delivery
Standard 1-3 working days
GO Lamp for 60003224. Lamp module for NEC PA600X/PA550W/PA500U Projector. Power = 330 Watts. Lamp life (Hours) = 3000 STD/4000 ECO. Alt part code = NP21LP. Now with 2 years warranty.
GO Lamps projector lamp
Projector lamp - 330 Watt
OEM Manufacturer Lamp Equivalent
NEC 60003224, NEC NP21LP
Bulb life cycle
3000 hour(s) (standard mode) / 4000 hour(s) (economic mode)
2 years warranty
NEC NP-PA500U, NP-PA500U-13ZL, NP-PA500X, NP-PA500X-13ZL, NP-PA550W, NP-PA550W-13ZL, NP-PA600X, NP-PA600X-13ZL, PA500U, PA500X, PA550W, PA600X
Projector lamp
Lamp
330 Watt
Life Cycle
Scroll to top
