BT.com
Wishlist
Gigabyte Z97P-D3 S1150 Intel Z97 4xDDR3 4xUSB3.0 10xUSB2.0 GBE ATX
Delivery
Standard Due date unavailable
GA-Z97P-D3 Intel® Z97 Chipset
  • Supports 4th and 5th Generation Intel® Core™ processors
  • Extreme multi graphics support
  • HD Audio support
  • LAN with high ESD Protection
  • GIGABYTE LAN Optimizer
  • Long lifespan Durable Solid caps
  • Supports HDMI output
  • APP Center including EasyTune™ and Cloud Station™ utilities
  • GIGABYTE UEFI DualBIOS™
Gigabyte GA-Z97P-D3 - 1.0 - motherboard - ATX - LGA1150 Socket - Z97
Motherboard - ATX
Chipset Type
Intel Z97 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC
Storage Ports
6 x SATA-600 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel Z97 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 2800 MHz (O.C.), 2933 MHz (O.C.), 2666 MHz (O.C.), 2600 MHz (O.C.), 2500 MHz (O.C.), 2400 MHz (O.C.), 2200 MHz (O.C.), 2133 MHz (O.C.), 2000 MHz (O.C.), 1866 MHz (O.C.), 1800 MHz (O.C.), 3000 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1 GB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
4 x DIMM 240-pin , 1 x CPU , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x16 (x4 mode) , 2 x PCIe 2.0 x1 , 2 x PCI
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Smart Response Technology
1 x PS/2 keyboard , 1 x HDMI , 1 x PS/2 mouse , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
6 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x serial - header , 1 x parallel - header , 1 x SPDIF out - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection, CPU core voltage
Hardware Features
Q-Flash, All-Solid Capacitor motherboard Design, Intel Extreme Memory Profile (XMP) support, On/Off Charge, Intel Smart Response Technology, Ultra Durable, AMD CrossFireX technology support, Intel Rapid Start Technology, Intel Smart Connect Technology, GIGABYTE LAN Optimizer, ESD Protection, Clear CMOS Button, GIGABYTE Smart Switch
Software Included
Norton Internet Security, @BIOS, EasyTune, Cloud Station, GIGABYTE EZ Setup, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, Smart TimeLock, GIGABYTE Fast Boot
Plug and Play, ACPI 5.0
30.5 cm
20 cm
Scroll to top
