BT.com
Wishlist
Gigabyte Z87X-UD4H S1150 Intel Z87 DDR3 ATX
Delivery
Standard Due date unavailable
GIGABYTE 8 Series motherboards support the latest 4th Generation Intel® Core™ processors, bringing together a unique blend of features and technologies that offer the absolute ultimate platform for your next PC build. From high current capable digital power delivery, performance-enhancing caching technologies, exclusive high-end audio features, advanced networking and device charging, gold plated hardware connectors and of course, killer good looks, GIGABYTE 8 series motherboards are in a class of their own.
Next Gen Intel® 8 Series Platform
The latest Intel 8 Series platform offers significant improvements in performance and power consumption with the latest 4th generation Intel® Core™ processors and Intel® Z87 chipsets. As well as a boost in overall productivity, the latest HD4600 Intel® processor graphics provide native 4K resolution playback over standard HDMI connectivity, with significantly higher frame rates in the latest DX11 3D game titles.
  • Supports 4th Generation Intel® Core™ processors
  • GIGABYTE Ultra Durable™ 5 Plus Technology
  • All IR Digital Power design
  • GIGABYTE UEFI DualBIOS™
  • 15µ gold plated CPU socket
  • Multi-GPU Support
  • Durable black solid capacitors
  • GIGABYTE On/Off Charge™ 2 for USB devices
  • Intel® LAN with high ESD Protection
  • New Heatsink design for better cooling
  • Realtek ALC898 with High Quality 110dB SNR HD audio
  • Onboard Quick Buttons
  • Supports CFOS Speed Internet Accelerator Software
  • 10 USB 3.0 ports
GIGABYTE Ultra Durable™ 5 Plus debuts on GIGABYTE 8 Series motherboards, with a range of features and component choices that provide record-breaking performance, cool and efficient operation and extended motherboard lifespan.
All New Heat Sink Design
GIGABYTE motherboards feature new heatsink designs that offer uncompromisingly efficient cooling on key areas of the motherboard including the PWM area and chipset (PCH). GIGABYTE 8 Series motherboards offer both passive, active and water cooling support of the crucial PWM area so even the most aggressive and extreme configurations will be kept well within optimal thermal parameters.
Ultra Performance: All IR® Digital CPU Power Design
GIGABYTE Ultra Durable™ 5 Plus motherboards use industry-leading PWM controllers and PowIRstage™ ICs and from International Recifier®. These components are 100% digital, offering incredible precision in delivering power to your 4th Generation Intel® processor. Designed from the ground up to complement each other, these industry-leading PWM controllers and PowIRstage™ ICs from IR® are optimized for cool and efficient operation, allowing users to get the absolute maximum performance from their next PC build.
Ultra Safe: GIGABYTE UEFI DualBIOS™
GIGABYTE motherboards feature GIGABYTE DualBIOS™, an exclusive technology from GIGABYTE that protects arguably one of your PC's most crucial components, the BIOS. GIGABYTE DualBIOS™ means that your motherboard has both a 'Main BIOS' and a 'Backup BIOS', making users protected from BIOS failure due to virus attack, hardware malfunction, improper OC settings or power failure during the update process.
Ultra USB3+: 10 USB 3.0 Ports
GIGABYTE Ultra Durable™ 5 Plus motherboards offer more high speed connectivity than ever before, packing up to 10 USB 3.0 ports per board. Each of these 10 USB 3.0 ports are also provided with a dedicated fuse, ensuring that an unexpected malfunction on one port, will affect only that port, isolating potential damage and protecting other connected devices.
Gigabyte GA-Z87X-UD4H - 1.0 - motherboard - ATX - LGA1150 Socket - Z87
Motherboard - ATX
Chipset Type
Intel Z87 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7, Xeon E3-1200 series
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC
Storage Ports
8 x SATA-600 (RAID), 2 x eSATA-600 (RAID)
USB / FireWire Ports
6 x USB 3.0 + (4 x USB 3.0 + 6 x USB 2.0 via headers)
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel Z87 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 2800 MHz (O.C.), 2933 MHz (O.C.), 2666 MHz (O.C.), 2600 MHz (O.C.), 2500 MHz (O.C.), 2400 MHz (O.C.), 2200 MHz (O.C.), 2133 MHz (O.C.), 2000 MHz (O.C.), 1866 MHz (O.C.), 1800 MHz (O.C.), 3000 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1 GB
Audio
Audio Codec
Realtek ALC898
High Definition Audio
LAN
Network Controller
Intel I217V
Network Interfaces
Gigabit Ethernet
Expansion Slots
4 x DIMM 240-pin (1.5 V) , 1 x PCIe 3.0 x16 , 1 x PCIe 3.0 x16 (x8 mode) , 3 x PCIe 2.0 x1 , 1 x PCIe 2.0 x16 (x4 mode) , 1 x PCI , 1 x CPU
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , Marvell 88SE9172: SATA-600 -connectors: 2 x 7pin SATA, 2 x 7pin eSATA - 2 devices - RAID 0 / RAID 1
RAID Features
Intel Smart Response Technology
1 x DisplayPort , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 6 x USB 3.0 , 1 x DVI-D , 1 x VGA , 1 x PS/2 keyboard / mouse , 1 x TOSLINK , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack
Internal Interfaces
6 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x serial - header , 1 x audio - header , 1 x SPDIF in - header , 1 x SPDIF out - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection, CPU core voltage
Hardware Features
DualBIOS, Q-Flash, V-Check Points, ASUS Smart Fan II, Intel Extreme Memory Profile (XMP) support, NVIDIA 2-way SLI Technology Support, Onboard Quick Switches, Intel Smart Response Technology, One Port One Fuse, GIGABYTE 3D Power, AMD CrossFireX technology support, Intel Rapid Start Technology, Intel Smart Connect Technology, Front Audio Headphone Amplifier, ESD Protection, Ultra Durable 5 Plus, All IR digital power design, CFOS Speed Internet Accelerator Software support, GIGABYTE OPT Fan Support, On/Off Charge 2, 2x Copper PCB, Black Solid Capacitors
Software Included
Norton Internet Security, @BIOS, EasyTune, GIGABYTE EZ Setup, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, cFosSpeed
Plug and Play, ACPI 2.0a
30.5 cm
24.4 cm
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Review Update - Now Working Fine
Reviewed by Rob on 23/04/2014
Gigabyte technical support responded promptly and I was able to resolve failure to start and get PC up and running. They actually provide support to individuals in the event that you can't find the answer on the Gigabyte forums. Board quality is superb - much stronger and heavier than any board I'd installed previously. Fits perfectly into the new Corsair case - all securing screws lined up. Dual BIOS useful and there are 3 ways of flashing to install an update. In fact I had more problems installing Win 7 which I now know thinks you are installing a RAID setup if you connect more than 1 HDD prior to operating system installation.
1* Currently unusable
Reviewed by Rob on 11/04/2014
I have a question into Gigabyte tech support. This is a new build. Initially fans repeatedly turned on then off. Spotted it was switching between the 2 Bioses. Turned off standby bios. Fans started and stayed on but impossible to get Bios displayed on my monitor. Resetting CMOS was no use. May have to return as I am likely to end up a MBoard with only 1 working Bios and no standbya and also if I had to clear the CMOS in the future I would end up with a PC that can't be started again. Someone on Tom's Hardware forum has had similar problem. Will update once I hear from Gigabyte.
Scroll to top
