BT.com
Wishlist
Gigabyte Z87X-OC S1150 Intel Z87 DDR3 ATX
Delivery
Standard Due date unavailable
GIGABYTE 8 series motherboards debut a number of exclusive new and improved features that are designed specifically to help enthusiasts and overclockers not only get the most performance from their hardware, but also the absolute most enjoyable OC experience.
GIGABYTE Z87X-OC
Designed specifically for the purpose of breaking OC records, the GIGABYTE Z87X-OC offers unique and exclusive OC features that have never been seen before on a motherboard. Giving pro and enthusiast overclockers the edge on LN2, the GIGABYTE Z87X-OC sits at the bleeding edge of technical possibility, pushing the outer limits of performance.
  • Supports 4th Generation Intel® Core™ processors
  • GIGABYTE Ultra Durable™ 5 Plus Technology
  • All IR Digital Power design
  • GIGABYTE UEFI DualBIOS™
  • Exclusive GIGABYTE OC Features
  • GIGABYTE Memory safe/Setting Lock/Direct to BIOS
  • Unique OC Ignition Feature
  • Unique OC Brace Feature
  • Gold plated DDR/PCIe Slots and power connectors
  • Premium 4-way CrossFire™ support
  • Durable black solid capacitors
  • GIGABYTE On/Off Charge™ 2 for USB devices
  • Intel® LAN with high ESD Protection
  • New Heatsink design with 8 onboard fan connectors
  • 10 USB 3.0 ports
OC Ignition (Patent Pending)
There are occasions as an overclocker when you want to shut down the system without turning off the power to other parts of the system, for example the drives and system fans. This is where OC Ignition is really useful.
Hitting the OC Ignition button gives continuous, uninterrupted power to all the motherboard's connected drives and system fans, but not to the CPU. This is useful in 'cold bug' situations when you need to heat the CPU to a bootable temperature, but you'd prefer the fans to keep spinning, reducing moisture build-up.
Overclockers using i-ram drives may also want to maintain SATA power and not risk losing their customized OS install while users with regular SSDs or HDDs also know that frequent powering on and off is harmful to your drives in the long-term.
OC Ignition is also useful in allowing users to pre-test water cooling setups, and even allows case mod demos to be developed without having to fully turn on the PC.
  • Powers fans and drives without booting or powering the CPU
  • Active fans help to reduce moisture build-up when using LN2
  • Maintain continuous uninterrupted power to drives
  • Safely powers water cooling systems for safe leak checking
  • Test demo and case mod systems without needing to boot the system
OC PCIe Switch
Overclockers can manually turn on or off each installed PCIe lane of the motherboard allowing users to effortlessly remove graphic cards from the system without the hassle of physically removal. This is especially convenient for VGA overclocking on LN2 and water cooled systems.
OC PEG
OC Peg adds auxiliary power to the PCIe slots of your motherboard, improving system stability in extreme configurations. This is especially useful in power-hungry 4-way graphics configurations.
OC Brace
OC Brace allows extreme overclockers and system testers to safely install up to four graphics cards in an open case or test bed without risking PCIe slot damage or preventing cards not showing up in the OS due to poor contact with the PCIe slot. OC Brace is a simple and elegant way to give robust installation support to full sized graphics cards in extreme multi-GPU configurations, including LN2 benching with cumbersome GPU pots that a need stable, solid installation base over extended periods.
Extreme Multi-GPU Support
Optimized support for AMD CrossFire™ in 4 way configurations plus support for NVIDIA SLI technology in 2-way setups. This extreme design allows a more optimized multiple-card overclocking experience where the first 3 slots have the data bandwidth available from trace paths direct from the CPU and the fourth slot taking PCIe lanes from the Intel® Z87 PCH.
Gigabyte GA-Z87X-OC - 1.0 - motherboard - ATX - LGA1150 Socket - Z87
Motherboard - ATX
Chipset Type
Intel Z87 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7, Xeon E3-1200 series
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC
Storage Ports
6 x SATA-600 (RAID)
USB / FireWire Ports
6 x USB 3.0 + 4 x USB 2.0 + ( 4 x USB 3.0 + 4 x USB 2.0 via headers )
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel Z87 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 3000 MHz, 2933 MHz
Supported RAM Integrity Check
Non-ECC
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1 GB
Audio
Audio Codec
Realtek ALC892
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
4 x DIMM 240-pin ( 1.5 V ) , 1 x PCIe 3.0 x16 , 1 x PCIe 3.0 x16 ( x8 mode ) , 1 x PCIe 3.0 x16 ( x4 mode ) , 1 x PCIe 2.0 x16 ( x4 mode ) , 1 x PCIe 2.0 x1 , 2 x PCI
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Smart Response Technology
1 x DisplayPort , 2 x HDMI , 1 x LAN (Gigabit Ethernet) , 6 x USB 3.0 , 2 x USB 2.0 , 1 x TOSLINK , 1 x PS/2 keyboard / mouse , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.0 - header , 2 x USB 2.0 - Type A , 1 x audio - header , 1 x SPDIF out - header , 1 x SPDIF in - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection, CPU core voltage
Hardware Features
DualBIOS, Q-Flash, Intel Extreme Memory Profile (XMP) support, NVIDIA 2-way SLI Technology Support, GIGABYTE OC-Touch, GIGABYTE OC-PEG, AMD CrossFireX technology support, AMD 3-way CrossFireX technology support, Intel Rapid Start Technology, Intel Smart Connect Technology, AMD 4-way CrossFireX technology support, ESD Protection, Ultra Durable 5 Plus, All IR digital power design, GIGABYTE OPT Fan Support, On/Off Charge 2, GIGABYTE Memory safe, GIGABYTE Setting Lock, GIGABYTE Direct to BIOS, Black Solid Capacitors, GIGABYTE OC Ignition, GIGABYTE OC Brace, GIGABYTE OC PCIe Switch, GIGABYTE OC Connect, onboard voltage measurement module
Software Included
Norton Internet Security, EasyTune, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, cFosSpeed
Plug and Play, ACPI 2.0a
30.5 cm
24.4 cm
Scroll to top
