BT.com
Wishlist
Gigabyte Z87N-WIFI S1150 Intel Z87 DDR3 ITX
Delivery
Standard Due date unavailable
GIGABYTE 8 Series motherboards support the latest 4th Generation Intel® Core™ processors, bringing together a unique blend of features and technologies that offer the absolute ultimate platform for your next PC build. From high current capable digital power delivery, performance-enhancing caching technologies, exclusive high-end audio features, advanced networking and device charging, gold plated hardware connectors and of course, killer good looks, GIGABYTE 8 series motherboards are in a class of their own.
Next Gen Intel® 8 Series Platform
The latest Intel 8 Series platform offers significant improvements in performance and power consumption with the latest 4th generation Intel® Core™ processors and Intel® Z87 chipsets. As well as a boost in overall productivity, the latest HD4600 Intel® processor graphics provide native 4K resolution playback over standard HDMI connectivity, with significantly higher frame rates in the latest DX11 3D game titles.
  • Supports 4th Generation Intel® Core™ processors
  • Mini ITX Form Factor (17*17cm)
  • GIGABYTE Ultra Durable™ 4 Plus Technology
  • Supports Intel® WiFi/ WIDI technology
  • Integrated Bluetooth 4.0 and Intel® Wi-Fi module
  • GIGABYTE Hybrid Digital Power Engine
  • GIGABYTE UEFI DualBIOS™
  • GIGABYTE 333™ Onboard Acceleration (USB 3.0, SATA 3.0 & 3x USB Power)
  • GIGABYTE On/Off Charge™ for USB devices
  • Dual LAN with high ESD Protection
  • Dual HDMI 1.4, DVI-I
GIGABYTE Ultra Durable™ 4 Plus debuts on GIGABYTE 8 Series motherboards, with a range of features and component choices that provide record-breaking performance, cool and efficient operation and extended motherboard lifespan.
Ultra Performance
GIGABYTE uses All Solid Caps (Capacitors) and Low RDS(on) MOSFETs which are rated to work at higher temperatures, providing up to 50,000* hour component lifespan.
Ultra Safe: GIGABYTE UEFI DualBIOS™
GIGABYTE motherboards feature GIGABYTE DualBIOS™, an exclusive technology from GIGABYTE that protects arguably one of your PC's most crucial components, the BIOS. GIGABYTE DualBIOS™ means that your motherboard has both a 'Main BIOS' and a 'Backup BIOS', making users protected from BIOS failure due to virus attack, hardware malfunction, improper OC settings or power failure during the update process.
Gigabyte GA-Z87N-WIFI - 1.0 - motherboard - mini ITX - LGA1150 Socket - Z87
Motherboard - mini ITX
Chipset Type
Intel Z87 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7, Xeon E3-1200 series
Max RAM Size
16 GB
RAM Supported
2 DIMM slots - DDR3 , non-ECC
Storage Ports
4 x SATA-600 (RAID)
USB / FireWire Ports
4 x USB 3.0 + 2 x USB 2.0 + ( 2 x USB 3.0 + 2 x USB 2.0 via headers )
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
802.11b/g/n, Bluetooth, 2 x Gigabit Ethernet
Chipset Type
Intel Z87 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 2666 MHz
Supported RAM Integrity Check
Non-ECC
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1 GB
Audio
Audio Codec
Realtek ALC892
High Definition Audio
LAN
Network Controller
Intel I217V / Atheros AR8161B
Network Interfaces
Expansion Slots
2 x DIMM 240-pin ( 1.5 V ) , 1 x PCIe 3.0 x16 , 1 x CPU , 1 x Mini PCIe
Storage Interfaces
SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Smart Response Technology
1 x DVI-I , 2 x HDMI , 2 x LAN (Gigabit Ethernet) , 2 x USB 2.0 , 4 x USB 3.0 , 1 x PS/2 keyboard / mouse , 1 x TOSLINK , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack
Internal Interfaces
1 x serial - header , 2 x USB 3.0 - header , 2 x USB 2.0 - header , 1 x SPDIF out - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage
Hardware Features
DualBIOS, Q-Flash, ASUS Smart Fan II, Intel Extreme Memory Profile (XMP) support, On/Off Charge, Intel Smart Response Technology, One Port One Fuse, GIGABYTE 333 Onboard Acceleration, Intel Rapid Start Technology, Intel Smart Connect Technology, ESD Protection, Intel Wireless Display (WiDi), Ultra Durable 4 Plus, GIGABYTE Hybrid digital power engine, Wi-Fi Share
Software Included
@BIOS, EasyTune, Cloud Station, GIGABYTE EZ Setup, Xpress Install, GIGABYTE App Center, Smart TimeLock
Plug and Play, ACPI 2.0a
17 cm
17 cm
Scroll to top
