BT.com
Wishlist
Gigabyte Z77X-UP7 S1155 Intel Z77 DDR3 ATX
Delivery
Standard Due date unavailable
GIGABYTE has unleashed its latest flagship Z77X-UP7 Motherboard. Designed for extreme overclocking, the GIGABYTE Z77X-UP7 motherboard is for serious overclockers looking to take down world records. Currently the Intel® Core™ i7 CPU world record holder at 7.102GHz, the GIGABYTE Z77X-UP7 is this year's overclocking motherboard to beat.
Industry Leading 32+3+2 Phase CPU Power Design
The GIGABYTE Z77X-UP7 motherboard delivers some serious amount of power through its 32+3+2 power phase design (32 CPU phases, 3 Intel® HD Graphics, 2 VTT phases). Featuring the new GIGABYTE Ultra Durable™ 5 technology with high current capable components including 60A rated PowIRstages® from IR, the Z77X-UP7 is able to deliver an astonishing 2,000W of power delivery.
True All Digital PWM Design
The GIGABYTE Z77X-UP7 motherboard takes advantage of an exclusive All Digital Engine to deliver maximum power to 3rd generation Intel® Core™ processors. Using entirely digital controllers means that more precise power delivery to the motherboard's most power hungry and energy sensitive components is possible
GIGABYTE 3D Power Utility
GIGABYTE Z77 series motherboards feature an All Digital Engine to deliver power to the CPU, processor graphics and VTT and system memory. This All Digital Engine features Precise Auto Voltage Compensation, providing exceptional control over the way power is delivered to your GIGABYTE 7 series motherboard.
Ultra Durable™ 5
Cool Power, Inside and Out: Our Best Ultra Durable™ Motherboards Yet. GIGABYTE is yet again raising the bar of motherboard quality and durability with our latest Ultra Durable™ 5 technology, featuring a range of High Current Capable components that provide the highest quality power delivery to the CPU for record-breaking performance, cool and efficient operation and extended motherboard lifespan.
4-Way Graphics
The GIGABYTE Z77X-UP7 delivers the industry's most scalable graphics platform, with support for both 4-way ATI CrossfireX™ and Nvidia SLI™. Providing 4 PCI Express 3.0 x8 connectivity, the Z77X-UP7 delivers ultra smooth 3D rendering, blazing-fast frame rates and enhanced graphics capabilities for users wanting to get the highest level of graphics performance from their system.
Native PCIe Gen. 3 x16 Direct Link to CPU
Single black PCIe x16 slot provides a direct link to the CPU, enabling it to bypass the PLX chip. This provides the fastest possible connection for single graphics card benching.
OC-Touch
OC-Touch enables overclockers to quickly and easily get the best performance from their system. Onboard OC-Touch buttons allow overclockers to manually adjust the CPU ratio, BCLK settings as well as adjustments to the BCLK stepping ratio, to either 1MHz or 0.1MHz increments. These changes can be made in real-time, whether in BIOS, DOS, or Windows® without the need for rebooting, so that users can quickly fine-tune their system and find their CPU's maximum frequency. Onboard voltage measurement modules are also included to help users to conveniently monitor individual component voltages and onboard LN2 Mode switch allows users to quickly drop CPU frequency to x16 multiplier during extreme overclocking so that opening benching applications such as CPU-Z will not cause the overclock to fail.
Thin Fin Cooling Design
GIGABYTE has created a new "Thin Fin" heatsink design featuring the GIGABYTE signature OC Orange look and feel for its latest flagship motherboard. Featuring ultra thin metal fins, the heatsink provides greater surface area so that quicker heat exchange can occur.
Gigabyte GA-Z77X-UP7 - 1.0 - motherboard - extended ATX - LGA1155 Socket - Z77
Motherboard - extended ATX
Chipset Type
Intel Z77 Express
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Celeron, Core i5, Core i3, Core i7, Pentium G600 series, Pentium G800 series, Xeon E3-1200 series
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC
Storage Ports
6 x SATA-600 (RAID), 4 x SATA-300 (RAID)
USB / FireWire Ports
6 x USB 3.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
802.11b/g/n, Bluetooth, 2 x Gigabit Ethernet
Chipset Type
Intel Z77 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
2400 MHz, 1600 MHz, 1333 MHz, 1066 MHz
Supported RAM Integrity Check
Non-ECC
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
Audio Codec
Realtek ALC898
High Definition Audio
LAN
Network Interfaces
Expansion Slots
1 x CPU , 4 x DIMM 240-pin (1.5 V) , 1 x PCIe 3.0 x16 , 2 x PCIe 3.0 x16 (x16 mode (x8 mode if all PCI Express 3.0 x8 slots are occupied)) , 2 x PCIe 3.0 x16 (x8 mode) , 2 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 4 x 7pin SATA, 1 x mSATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , Marvell 88SE9172: SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1
RAID Features
Intel Smart Response Technology
1 x VGA , 1 x DVI-D (dual link) , 1 x HDMI , 1 x PS/2 keyboard / mouse , 1 x TOSLINK , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x DisplayPort , 2 x LAN (Gigabit Ethernet) , 6 x USB 3.0
Internal Interfaces
1 x audio - header , 1 x SPDIF in - header , 1 x SPDIF out - header , 2 x USB 3.0 , 6 x USB 2.0 , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector, 6-pin PCI Express power connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
Hardware Features
DualBIOS, Q-Flash, GIGABYTE eXtreme Hard Drive (XHD), AutoGreen, NVIDIA 3-way SLI Technology Support, Intel Extreme Memory Profile (XMP) support, NVIDIA 2-way SLI Technology Support, On/Off Charge, GIGABYTE OC-Touch, Intel Smart Response Technology, GIGABYTE 3D Power, NVIDIA 4-way SLI Technology Support, GIGABYTE 333 Onboard Acceleration, AMD CrossFireX technology support, AMD 3-way CrossFireX technology support, Intel Rapid Start Technology, Intel Smart Connect Technology, Lucid Virtu MVP, Onboard mSATA Connector, AMD 4-way CrossFireX technology support, Ultra Durable 5, 32+3+2 Phase Power Design, GIGABYTE Thin Fin Cooling Design, 80-port Debug Display
Bluetooth / Wi-Fi module
Software Included
Norton Internet Security, @BIOS, Xpress Recovery 2, Q-Share, EasyTune, GIGABYTE 3D Power, GIGABYTE EZ Setup, Xpress Install
Plug and Play, ACPI 2.0a
30.5 cm
26.4 cm
Scroll to top
