Click to visit BT.com
BT.com
Wishlist
Gigabyte Z77X-UD4H S1155 Intel Z77 DDR3 ATX
Quicklinx: 8JZDWS00
Mfr#: GA-Z77X-UD4H
Essential accessories
Gigabyte 7 series motherboard combines a host of exciting technologies with the Intel Z77 Express Chipset, creating a unique range of motherboard designs that harness the outstanding performance of the Intel Core processor. With an exclusive 'Digital' VRM design, Gigabyte 3D Power and Gigabyte 3D BIOS (Dual UEFI), Gigabyte 7 series motherboard ensures exceptional power delivery and absolute control, with additional features that ensure an unrivaled experience on your next PC build.
Gigabyte GA-Z77X-UD4H - 1.0 - motherboard - ATX - LGA1155 Socket - Z77
Motherboard - ATX
Chipset Type
Intel Z77 Express
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
DDR3 , non-ECC
Storage Ports
4 x SATA-600 (RAID), 4 x SATA-300 (RAID), 2 x eSATA-600 (RAID)
USB / FireWire Ports
6 x USB 3.0 + ( 2 x USB 3.0 + 6 x USB 2.0 via headers )
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel Z77 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
Supported RAM Integrity Check
Non-ECC
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
Audio Codec
Realtek ALC892
High Definition Audio
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin ( 1.5 V ) , 1 x PCIe 3.0 x16 ( x16 mode (x8 mode if all PCI Express 3.0 x8 slots are occupied) ) , 1 x PCIe 3.0 x16 ( x8 mode ) , 1 x PCIe 3.0 x16 ( x4 mode ) , 3 x PCIe 2.0 x1 ( auto turn-off if all PCI Express 3.0 x4 slots are occupied ) , 1 x PCI
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , Marvell 88SE9172 : SATA-300 -connectors: 2 x 7pin SATA, 2 x 7pin eSATA - 4 devices - RAID 0 / RAID 1
1 x PS/2 keyboard / mouse , 6 x USB 3.0 , 1 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DVI-D , 1 x HDMI , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK , 1 x microphone - mini-jack
Internal Interfaces
2 x USB 3.0 , 6 x USB 2.0 , 1 x SPDIF out , 1 x audio
Power Connectors
24-pin main power connector, 8-pin ATX12V connector, 6-pin PCI Express power connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
Hardware Features
DualBIOS, Q-Flash, 8 Phase Power Design, GIGABYTE eXtreme Hard Drive (XHD), AutoGreen, V-Check Points, Intel Extreme Memory Profile (XMP) support, NVIDIA 2-way SLI Technology Support, On/Off Charge, GIGABYTE 333 Onboard Acceleration, AMD Hybrid CrossFireX technology support, Intel Rapid Start Technology, Lucid Virtu MVP, GIGABYTE LAN Optimizer, Ultra Durable 4
Software Included
Norton Internet Security, @BIOS, Q-Share, EasyTune, GIGABYTE EZ Smart Response, GIGABYTE 3D Power, GIGABYTE EZ Setup
Plug and Play, ACPI 2.0a
30.5 cm
24.4 cm
