Gigabyte Z77X-D3H S1155 Intel Z77 DDR3 ATX
Standard Due date unavailable
GIGABYTE 7 series motherboards combine a host of new and exciting technologies with the latest Intel Z77 Express Chipset, creating a unique range of motherboard designs that harness the outstanding performance of the new 3rd generation Intel® Core™ processors. With an exclusive 'All Digital' VRM design, GIGABYTE 3D Power and GIGABYTE 3D BIOS (Dual UEFI), GIGABYTE 7 series motherboards ensure exceptional power delivery and absolute control, with additional features that ensure an unrivalled experience on your next PC build.
  • Support for the new INTEL 3rd Generation CPU's. On the socket 1155 platform.
  • USB 3x Power Boost. Delivering greater device compatibility and faster charge times.
  • Ultra Durable 4 Classic. Advanced temprature, humidity, electrostatic and power failure protection... The ultimate in reliability.
  • Super Speed USB 3.0. Super fast transfer rates of up to 5 Gbps, 10x faster than USB 2.0.
  • Lucid Virtu MVP. Producing faster frame rates, with sharper visuals and reduced tearing.
  • Super SATA3 Native Suport. Supporting super fast 6Gbps link speeds.
  • NVIDIA SLI and AMD Crossfirex. For multi display or ultimate performace gaming.
  • PCIe GEN 3. Designed to take full advantage of the next generation high bandwidth graphic card solutions.
  • UEFI DualBIOS™. A superior graphical BIOS interface, based on the trusted and secure GIGABYTE Dual BIOS technology.
  • ON/OFF Charge Technology. Allows you to charge your iPad, iPhone or iPod even of your PC is off.
  • Onboard mSATA Connector. Mount a low capcity mSATA SSD onto your motherboard to take advantage of INTEL SRT and RAPID START.
Tech Spec / Z77X-D3H
  • CPU: Support for Intel Core i7, i5, i3, Pentium and Celeron 1155 processors(Go to GIGABYTE's website for the latest CPU support list.)
  • Chipset: Intel Z77 Express Chipset
  • Memory: 4x DDR3 1600/1333/1066 MHz memory modules * Due to Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
  • Onboard Graphics: 1x D-Sub, 1x DVI-D (1920x1200 max res), 1x HDMI (1920x1200 max res)
  • Audio: VIA VT2021 codec High Definition Audio 2/4/5.1/7.1-channel w/ Support for S/PDIF Out
  • Multi-Graphics: Support for 2-Way AMD CrossfireX/NVIDIA SLI Technology (16x and 8x)
  • LAN: 1 x Atheros GbE chip (10/100/1000 Mbit)
  • Expansion Slots: 1 x PCI Express x16 slots, running at x16 / 1 x PCI Express x16 slots, running at x8 / 1 x PCI Express x16 slots, running at x4 / 3x PCI Express x1 slot / 1x PCI slots
  • Storage Interface: 4 x SATA 6Gb/s connectors / 4 x SATA 3Gb/s connectors / 1 x mSATA 3Gb/s (Disables sata connector 5 when in use) / 2 x eSATA 6Gb/s on back panel
  • USB: USB 3.0/2.0 : 6x on the back panel, 2x via USB brackets on headers / USB 2.0/1.1 : 2x on the back panel, 4x via USB brackets on headers
  • Internal I/O Connectors: 1 x 24-pin ATX main power connector, 1 x 4-pin ATX 12V power connector, 4x SATA 6Gb/s connector, 4 x SATA 3GB/s connectors, 1 x mSATA connector, 1 x CPU fan header, 3x system fan headers, 1 x front panel header, 1 x front panel audio header, 1 x S/PDIF Out header, 2x USB 2.0/1.1 headers, 1 x USB 3.0/2.0 headers,1 x clearing CMOS jumper, 1 x TPM header, 1 x Serial port header
  • Back Panel Connectors: 1 x PS/2 keyboard/mouse port, 1 x D-Sub, 1 x DVI-D, 1 x HDMI, 1 x Optical S/PDIF Out connector, 6 x USB 3.0/2.0 ports, 2 x USB 2.0/1.1 ports, 1 x RJ-45 ports, 5x audio jacks
  • BIOS: 2 x 64 Mbit AMI EFI BIOS, Support for DualBIOS™
  • Form Factor: ATX Form Factor; 30.5 x 24.4cm
  • Warranty: 3 Year Gigabyte Warranty
Gigabyte GA-Z77X-D3H - 1.0 - motherboard - ATX - LGA1155 Socket - Z77
Motherboard - ATX
Chipset Type
Intel Z77 Express
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC
Storage Ports
4 x SATA-600 (RAID), 4 x SATA-300 (RAID)
USB / FireWire Ports
6 x USB 3.0 + 2 x USB 2.0 + ( 2 x USB 3.0 + 4 x USB 2.0 via headers )
HD Audio (8-channel)
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Motherboard - ATX
Chipset Type
Intel Z77 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
Supported RAM
Max Size
32 GB
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
PC3-12800, PC3-10600, PC3-8500
Supported RAM Integrity Check
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio Codec
VIA VT2021
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin ( 1.5 V ) , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x16 , 1 x PCIe 2.0 x16 , 3 x PCIe 2.0 x1 , 1 x PCI
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 4 x 7pin SATA, 1 x mSATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , Marvell 88SE9172: SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1
RAID Features
Intel Smart Response Technology
1 x PS/2 keyboard / mouse , 2 x USB 2.0 , 6 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DVI-D , 1 x HDMI , 1 x audio line-out - mini-jack , 1 x audio line-in/microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK
Internal Interfaces
2 x USB 3.0 , 4 x USB 2.0 , 1 x SPDIF out , 1 x audio , 1 x serial
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Features
DMI 2.0 support, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS, GIGABYTE 3D BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
Hardware Features
DualBIOS, Q-Flash, NVIDIA SLI Technology Support, GIGABYTE eXtreme Hard Drive (XHD), AutoGreen, Intel Extreme Memory Profile (XMP) support, On/Off Charge, Intel Smart Response Technology, GIGABYTE 3D Power, GIGABYTE 333 Onboard Acceleration, Ultra Durable 4 Classic, AMD CrossFireX technology support, Intel Rapid Start Technology, Intel Smart Connect Technology, Lucid Virtu MVP, GIGABYTE LAN Optimizer, Onboard mSATA Connector
Software Included
Norton Internet Security, @BIOS, Xpress Recovery 2, Q-Share, GIGABYTE EZ Smart Response, GIGABYTE 3D Power
Plug and Play, ACPI 2.0a
30.5 cm
24.4 cm
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Great Board
Reviewed by niki on 05/10/2012
Very impressive looking board, that really looks well made. No installation issues whatsoever, except the new mouse driven interface for the BIOS is a little illogical and difficult to work. It's changed a lot since the previous generation of boards, so expect to have to take a little time to work it all out. Stick at it though, because it does the job. Don't forget that unless you have stock RAM you will need to set the timing and this is rather clumsy in the BIOS. It takes a while to work out how the interface works.
In particular I found the SATAIII gave a HUGE increase in speed with an SSD. Apart from that, really, not much to say. It's a very compatible, very good board.
Scroll to top
