Gigabyte Z77MX-D3H S1155 Intel Z77 DDR3 mATX
Standard Due date unavailable
Gigabyte 7 series motherboard combines a host of exciting technologies with the Intel Z77 express chipset, creating a unique range of motherboard designs that harness the outstanding performance of the Intel Core processors. With an exclusive 'Digital' VRM design, Gigabyte 3D Power and Gigabyte 3D BIOS (Dual UEFI), Gigabyte 7 series motherboard ensures exceptional power delivery and absolute control, with additional features that ensure an unrivaled experience on your next PC build.
Gigabyte 7 series motherboard supports Lucid Virtu GPU virtualization technologies - optimized virtualization software that improves your PC's visuals, with faster response times, improved video processing and smoother media playback, all within a low power environment. Lucid Universal MVP also features Hyperformance, which eliminates redundant rendering tasks and predicts potential synchronization issues in the graphics delivery pipeline, producing faster frame rates, sharper visuals and reduced tearing.
Gigabyte 7 series motherboard features ON/OFF Charge, a unique Gigayte technology which allows you not only to charge your iPhone, iPad or iPod Touch, but also allows you to quick charge it. As an added bonus, it can even be charged when your PC is turned off, so even if you forget to plug it into your charger after you've synced up your music, it will be fully charged when you need it.
  • Support for the new INTEL 3rd Generation CPU's. On the socket 1155 platform.
  • USB 3x Power Boost. Delivering greater device compatibility and faster charge times.
  • Ultra Durable 4 Classic. Advanced temprature, humidity, electrostatic and power failure protection... The ultimate in reliability.
  • Super Speed USB 3.0. Super fast transfer rates of up to 5 Gbps, 10x faster than USB 2.0.
  • Lucid Virtu MVP. Producing faster frame rates, with sharper visuals and reduced tearing.
  • Super SATA3 Native Suport. Supporting super fast 6Gbps link speeds.
  • NVIDIA SLI / AMD Crossfirex. For multi display or ultimate performace gaming.
  • PCIe GEN 3. Designed to take full advantage of the next generation high bandwidth graphic card solutions.
  • UEFI DualBIOS™. A superior graphical BIOS interface, based on the trusted and secure GIGABYTE Dual BIOS technology.
  • ON/OFF Charge Technology. Allows you to charge your iPad, iPhone or iPod even of your PC is off.
Tech Spec / Z77MX-D3H
  • CPU: Support for Intel Core i7, i5, i3, Pentium and Celeron 1155 processors(Go to GIGABYTE's website for the latest CPU support list.)
  • Chipset: Intel Z77 Express Chipset
  • Memory: 4x DDR3 1600/1333/1066 MHz memory modules * Due to Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
  • Onboard Graphics: 1x D-Sub, 1x DVI-D (1920x1200 max res), 1x HDMI (1920x1200 max res)
  • Audio: VIA VT2021 codec High Definition Audio 2/4/5.1/7.1-channel w/ Support for S/PDIF Out
  • Multi-Graphics: Support for AMD CrossfireX/NVIDIA SLI Technology
  • LAN: 1 x Atheros GbE chip (10/100/1000 Mbit)
  • Expansion Slots: 1 x PCI Express x16 slots, running at x16 / 1 x PCI Express x16 slots, running at x8 / 1 x PCI Express x16 slots, running at x4 / 1x PCI Express x1 slot
  • Storage Interface: 2 x SATA 6Gb/s connectors / 4 x SATA 3Gb/s connectors
  • USB: USB 3.0/2.0 : 2x on the back panel, 2x via USB brackets on headers / USB 2.0/1.1 : 6x on the back panel, 4x via USB brackets on headers
  • Internal I/O Connectors: 1 x 24-pin ATX main power connector, 1 x 4-pin ATX 12V power connector, 2 x SATA 6Gb/s connector, 4 x SATA 3GB/s connectors, 1 x CPU fan header, 2 x system fan headers, 1 x front panel header, 1 x front panel audio header, 1 x S/PDIF Out header, 2x USB 2.0/1.1 headers, 1x USB 3.0/2.0 headers,1 x clearing CMOS jumper, 1 x TPM header
  • Back Panel Connectors: 1 x PS/2 keyboard/mouse port, 1 x D-Sub, 1 x DVI-D, 1 x HDMI, 1 x Optical S/PDIF Out connector, 2 x USB 3.0/2.0 ports, 6 x USB 2.0/1.1 ports,1 x RJ-45 ports, 5x audio jacks
  • BIOS: 2 x 64 Mbit AMI EFI BIOS, Support for DualBIOS™
  • Form Factor: mATX Form Factor; 24.4 x 24.4cm
  • Warranty: 3 Year Gigabyte Warranty
Gigabyte GA-Z77MX-D3H - 1.0 - motherboard - micro ATX - LGA1155 Socket - Z77
Motherboard - micro ATX
Chipset Type
Intel Z77 Express
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC
Storage Ports
2 x SATA-600 (RAID), 4 x SATA-300 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 6 x USB 2.0 + ( 2 x USB 3.0 + 4 x USB 2.0 via headers )
HD Audio (8-channel)
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Chipset Type
Intel Z77 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
Supported RAM
Max Size
32 GB
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
PC3-12800, PC3-10600, PC3-8500
Supported RAM Integrity Check
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio Codec
VIA VT2021
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin ( 1.5 V ) , 1 x PCIe 3.0 x16 , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x16 , 1 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Smart Response Technology
1 x PS/2 keyboard / mouse , 6 x USB 2.0 , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DVI-D , 1 x HDMI , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK
Internal Interfaces
2 x USB 3.0 , 4 x USB 2.0 , 1 x SPDIF out , 1 x audio
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Features
DMI 2.0 support, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS, GIGABYTE 3D BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
Hardware Features
DualBIOS, Q-Flash, NVIDIA SLI Technology Support, GIGABYTE eXtreme Hard Drive (XHD), AutoGreen, Intel Extreme Memory Profile (XMP) support, On/Off Charge, Intel Smart Response Technology, GIGABYTE 3D Power, GIGABYTE 333 Onboard Acceleration, Ultra Durable 4 Classic, AMD CrossFireX technology support, Intel Rapid Start Technology, Intel Smart Connect Technology, Lucid Virtu MVP, GIGABYTE LAN Optimizer
Software Included
@BIOS, Xpress Recovery 2, Q-Share, GIGABYTE EZ Smart Response, GIGABYTE 3D Power
Plug and Play, ACPI 2.0a, Energy-Related Products (ErP) Lot 6
24.4 cm
24.4 cm
Scroll to top
