BT.com
Wishlist
Gigabyte Z68X-UD3P S1155 Intel Z68 Express DDR3 ATX (USB 3.0)
Delivery
Standard Due date unavailable
GIGABYTE Z68 series motherboards provide all the advanced overclocking features users have come to know and love about the GIGABYTE P67 series motherboards including increasing processor core ratios, increasing DDR3 memory ratios and increasing power and current limits. In addition, GIGABYTE Z68 motherboards also allow users to increase the graphics core clock speed, for even greater graphics performance.
GIGABYTE Touch BIOS™ (Patent Pending)
An Innovative New Way to Modify BIOS Settings
Navigating through the BIOS to change system settings can be a daunting task for users not familiar with control "F"functions and mouse-less navigation. While some EFI BIOS try to address this with a mouse friendly environment, many implementations still lack a certain ease-of-use necessary for most people. With GIGABYTE Touch BIOS™, GIGABYTE engineers have completely re-imagined how users can interact with their BIOS, allowing for a more intuitive user experience. In fact, with a touch screen monitor, GIGABYTE Touch BIOS™ is as easy to use as most apps on your iPhone. Supports Intel® Smart Response Technology
Faster than HDD-only system
GIGABYTE Z68 series motherboards are equipped with the much anticipated Intel® Smart Response Technology, allowing users to experience system performance similar to SSD only systems. Intel® Smart Response technology works by using intelligent block-based caching of frequently used applications to improve system performance and responsiveness. In fact, GIGABYTE Z68 motherboards with Intel® Smart Response Technology are able to outperform hybrid drive systems by more than 2X (PC Mark Vantage) and HDD-only systems by as much as 4X (PC Mark Vantage).
SuperSpeed USB 3.0
GIGABYTE Ultra Durable™ 3 motherboards boast SuperSpeed USB 3.0 technology made possible through an additional onboard host controller. With superfast transfer rates of up to 5 Gbps, users are able to experience a theoretical 10x improvement over USB 2.0. Additionally, backwards compatibility with USB 2.0 assures users of long term use of their legacy USB 2.0 devices.
SATA 6 Gbps
GIGABYTE motherboards are High-Speed SATA Revision 3.0 compatible, delivering superfast 6Gbps link speeds for twice the data transfer rates of SATA Revision 2.0 (3 Gbps). When used in RAID 0 (Stripe) mode, they offer even faster data transfer rates of up to a theoretical 4x the speed of current SATA interfaces.
Gigabyte GA-Z68X-UD3P-B3 - 1.0 - motherboard - ATX - LGA1155 Socket - Z68
Motherboard - ATX
Chipset Type
Intel Z68 Express / ITE IT8728
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC
Storage Ports
4 x SATA-600 (RAID), 4 x SATA-300 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 1 x FireWire + 8 x USB 2.0 + ( 2 x USB 3.0 + 1 x FireWire + 6 x USB 2.0 via headers )
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Motherboard - ATX
Chipset Type
Processor Socket
LGA1155 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2133 MHz
Speed
PC3-12800, PC3-10600, PC3-8500
Supported RAM Integrity Check
Non-ECC
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
Audio Codec
Realtek ALC889
High Definition Audio, Dolby Home Theater
LAN
Network Controller
Realtek RTL8111E
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin ( 1.5 V ) , 1 x PCIe 2.0 x16 , 1 x PCIe 2.0 x16 , 3 x PCIe 2.0 x1 , 2 x PCI
Storage Interfaces
SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , Marvell 88SE9172: SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1
1 x PS/2 keyboard / mouse , 1 x TOSLINK , 1 x FireWire - 6 pin FireWire , 8 x USB 2.0 , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
1 x SPDIF out , 3 x USB 2.0 , 1 x USB 3.0 , 1 x FireWire , 1 x serial , 1 x audio
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
Award
BIOS Features
DMI 2.0 support, ACPI 1.0b support, SMBIOS 2.4 support
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection, power supply fan tachometer
Hardware Features
DualBIOS, Q-Flash, NVIDIA SLI Technology Support, Smart 6, GIGABYTE Dynamic Energy Saver (DES) 2, 12 Phase Power Design, GIGABYTE eXtreme Hard Drive (XHD), AutoGreen, 3x USB Power Boost, Intel Extreme Memory Profile (XMP) support, Ultra Durable 3, On/Off Charge, GIGABYTE Hardware Overvoltage Control IC, Dual CPU Power Technology, GIGABYTE Turbo USB 3.0, GIGABYTE Turbo XHD, AMD CrossFireX technology support
4 x Serial ATA cable , 1 x SLI bridge
Software Included
Norton Internet Security, @BIOS, Xpress Recovery 2, Q-Share, Cloud OC, Hotkey OC, EasyTune
Plug and Play, ACPI 1.0b, Energy-Related Products (ErP) Lot 6
30.5 cm
24.4 cm
Scroll to top
