BT.com
Wishlist
Gigabyte X79-UD3 S2011 X79 Intel DDR3 ATX
Delivery
Standard Due date unavailable
GIGABYTE X79 series motherboards are designed to unite unrivalled desktop PC performance with a new level of flexibility and hardware control. Based on the latest Intel® X79 Express Chipset, supporting the new LGA 2011 Intel® Core™ i7 processors, GIGABYTE X79 series motherboards bring DIY builders to a new area of performance-oriented computing.
GIGABYTE 3D Power (patent pending)
GIGABYTE X79 series motherboards are the first to take advantage of the exclusive GIGABYTE 3D Power, an all new hardware and software-based Digital Power Engine for both the PWM and Memory that delivers unprecedented power delivery control.
All New Digital Power Control for the CPU and Memory
Utilizing a brand new Digital PWM controller, GIGABYTE's 3D Power features precise Auto Voltage Compensation to deliver a steady flow of power to the CPU and memory no matter the loading. This all new, all digital power system provides enthusiast users with exceptional control over the overclocking potential of their GIGABYTE X79 motherboard.
GIGABYTE is the first in the industry to utilize digital memory controllers for not only the Memory, but VTT and VSA, for real-time monitoring and adjusting. Digital memory control allows users to monitor and record DDR power and current in real-time while gaming, overclocking or at idle. Users can also set OVP (Over Voltage Protection) to safeguard your memory, adjust memory Load-line Calibration to fix memory vdrooping for a quicker response time and adjust memory PWM frequency on-the-fly.
High Performance Intel® Core™ i7 processors
Packing the latest Sandy-Bridge-E processor architecture, this new breed of Intel® Core™ i7 processors are a dream come true for serious gamers. Featuring the largest ever Smart Cache with L3 cache sizes of up 16MB and Intel® Turbo Boost Technology that can push clock speeds up 3.9GHz on up to six cores and 12 threads, you know you'll be one step ahead of the competition.
4 Channel Memory Architecture
With a potential data bandwidth of up to 25GB/Sec and 256 Bits memory addressing, the Intel® X79 platform offers unrivalled memory performance. GIGABYTE X79 series motherboards give you the ultimate performance for today's memory-intensive applications.
Most PCI Express Lanes Ever on the Desktop
GIGABYTE X79 motherboards take advantage of the most comprehensive PCI Express data bus ever seen on a desktop PC platform. The Intel® X79 platform integrates all PCI Express lanes in to the CPU, resulting in lower latency and even faster performance for the latest discrete GPU and multi-GPU configurations.
PCI Express Gen.3 Support
The GIGABYTE motherboard is fully configured to provide gamers with the latest Gen.3 PCI Express technology, delivering maximum data bandwidth for forthcoming discrete graphics cards. * PCIe Gen. 3 is dependent on CPU and expansion card compatibility.
4 Way Graphics Support
The GIGABYTE X79-UD3 delivers the industry's most scalable graphics platform, with support for both 4-way ATI CrossfireX™ and Nvidia SLI™. Providing 4 PCI Express 3.0 x8 connectivity, X79-UD3 delivers ultra smooth 3D rendering, blazing-fast frame rates and enhanced graphics capabilities for users wanting to get the highest level of graphics performance from their system.
SuperSpeed USB 3.0
GIGABYTE motherboards boast SuperSpeed USB 3.0 technology made possible through an additional onboard host controller. With superfast transfer rates of up to 5 Gbps, users are able to experience a theoretical 10x improvement over USB 2.0. Additionally, backwards compatibility with USB 2.0 assures users of long term use of their legacy USB 2.0 devices.
SATA 6 Gbps
GIGABYTE motherboards are High-Speed SATA Revision 3.0 compatible, delivering superfast 6Gbps link speeds for twice the data transfer rates of SATA Revision 2.0 (3 Gbps). When used in RAID 0 (Stripe) mode, they offer even faster data transfer rates of up to a theoretical 4x the speed of current SATA interfaces.
Gigabyte GA-X79-UD3 - 1.0 - motherboard - ATX - LGA2011 Socket - X79
Motherboard - ATX
Chipset Type
Intel X79 Express
Processor Socket
1 x LGA2011 Socket
Compatible Processors
Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC
Storage Ports
2 x SATA-600 (RAID), 2 x SATA-600 (RAID), 2 x SATA-600 (RAID), 4 x SATA-300 (RAID), 2 x eSATA-600
USB / FireWire Ports
2 x USB 3.0 + 8 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Motherboard - ATX
Chipset Type
Intel X79 Express
Processor Socket
LGA2011 Socket
Max Processors Qty
1
Core i7
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2133 MHz
Speed
PC3-12800, PC3-10600, PC3-8500
Supported RAM Integrity Check
Non-ECC
Quad channel memory architecture
Audio
Audio Codec
Realtek ALC898
High Definition Audio, Dolby Home Theater
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 3.0 x16 , 2 x PCIe 3.0 x16 , 2 x PCIe 2.0 x1 , 1 x PCI
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , Marvell 88SE9172: SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 , Marvell 88SE9172: SATA-600 -connectors: 2 x 7pin external SATA - 2 devices - RAID 0 / RAID 1
1 x PS/2 keyboard / mouse , 1 x TOSLINK , 1 x SPDIF out , 8 x USB 2.0 , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Internal Interfaces
1 x audio , 6 x USB 2.0 , 2 x USB 3.0 , 1 x serial
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS, GIGABYTE 3D BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
Hardware Features
DualBIOS, Q-Flash, Smart 6, GIGABYTE eXtreme Hard Drive (XHD), 3x USB Power Boost, Intel Extreme Memory Profile (XMP) support, Ultra Durable 3, On/Off Charge, GIGABYTE 3D Power, NVIDIA 4-way SLI Technology Support, AMD Quad CrossFireX technology support
Software Included
Norton Internet Security, @BIOS, Xpress Recovery 2, Q-Share, Cloud OC, EasyTune
Plug and Play, ACPI 2.0a
30.5 cm
24.4 cm
Scroll to top
