BT.com
Wishlist
Gigabyte X299-AORUS Ultra Gaming Intel X299 S2066 DDR4 M.2 USB3.1 ATX
Delivery
Standard Due date unavailable
Marketing description is not available.
Gigabyte X299 AORUS Ultra Gaming - 1.0 - motherboard - ATX - LGA2066 Socket - X299
Motherboard - ATX
Chipset Type
Intel X299 Express
Processor Socket
1 x LGA2066 Socket
Compatible Processors
Core X
Max RAM Size
512 GB
RAM Supported
8 DIMM slots - DDR4 registered, unbuffered
Storage Ports
8 x SATA-600 (RAID), 3 x M.2
USB / FireWire Ports
USB 3.1 Gen 1, USB-C Gen2, USB 3.1 Gen 2 1 x USB-C Gen 2 + 4 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + (1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel X299 Express
Processor Socket
LGA2066 Socket
Max Processors Qty
1
Core X
Supported RAM
Max Size
512 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3400 MHz (O.C.), 3333 MHz (O.C.), 3466 MHz (O.C.), 3733 MHz (O.C.), 3600 MHz (O.C.), 3666 MHz (O.C.), 3866 MHz (O.C.), 4000 MHz (O.C.), 4133 MHz (O.C.), 4400 MHz (O.C.), 4266 MHz (O.C.), 4333 MHz (O.C.)
Registered or Buffered
Registered, unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Details
128 GB - unbuffered , 512 GB - registered
Audio
Audio Codec
Realtek ALC1220
High Definition Audio, Sound BlasterX 720°
LAN
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 8 x DIMM 288-pin , 2 x PCIe 3.0 x16 , 1 x PCIe 3.0 x16 (x8 mode) , 2 x PCIe 3.0 x16 (x4 mode)
Storage Interfaces
SATA-600 -connectors: 8 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 2 x M.2 , PCIe 3.0 -connectors: 1 x M.2
1 x LAN (Gigabit Ethernet) , 4 x USB 3.1 Gen 1 , 4 x USB 3.1 Gen 2 , 1 x USB-C Gen2 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x PS/2 keyboard / mouse
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x Thunderbolt - header , 1 x SPDIF out - header , 1 x audio - header , 1 x USB 3.1 Gen 2 - header
Power Connectors
24-pin main power connector, 2 x 8-pin ATX12V connectors
BIOS Type
AMI
BIOS Features
WfM 2.0 support, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, Dual BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection, CPU core voltage
Hardware Features
Q-Flash, AutoGreen, NVIDIA 3-way SLI Technology Support, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, NVIDIA 2-way SLI Technology Support, On/Off Charge, Ultra Durable, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, Easy RAID Installer, Black Solid Capacitors, IR PowIRstage ICs, Turbo B-Clock, Game Boost, GIGABYTE Double Locking Bracket, Ultra Durable Memory Armor, Anti-Sulfur Design, G-Connector, Intel Optane Memory Ready, GIGABYTE Smart Fan 5, RGB FUSION, Ultra Durable PCIe Armor, RGBW/-UV LED strips support
Software Included
Norton Internet Security, @BIOS, EasyTune, Cloud Station, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center, cFosSpeed, Smart TimeLock, GIGABYTE Fast Boot, GIGABYTE V-Tuner, GIGABYTE Smart Keyboard, GIGABYTE Smart Backup, GIGABYTE Smart Fan 5, GIGABYTE 3D OSD, GIGABYTE Smart HUD
Plug and Play
30.5 cm
24.4 cm
Scroll to top
