Click to visit BT.com
BT.com
Wishlist
Gigabyte Pre-Assembled Value Bundle (Includes H61MA-D2V, Intel Pentium Dual Core G2020 & 4GB XMS3)
Quicklinx: 8HJCWS00
Mfr#: GBTINTEL-VALUE1
Essential accessories
Exclusive Pre-Assembled Bundle: High Performance - Without The High Price Tag!
Take the fear out of Self-Build with this Gigabyte Intel Value Bundle! This Bundle - which includes Motherboard, CPU & Memory - has been tested to ensure Guaranteed Compatilbity and are pre-assembled ready to use out of the box!*
Gigabyte H61MA-D2V S1155 Intel H61 DDR3 ATX Motherboard
The Gigabyte motherboard is fully configured to provide gamers with the generation 3 PCI Express technology, delivering maximum data bandwidth for forthcoming discrete graphics cards.
Gigabyte ultra durable motherboard is equipped with solid capacitors developed by leading Japanese manufacturers. With an average lifespan of 50,000 hours, these solid capacitors provide the stability, reliability and longevity essential to meet the power needs of high-end processors and other components running today's most demanding applications and games...
Intel Pentium Dual Core G2020 2.9GHz S1155 3MB Processor (BX80637G2020)
The Intel Pentium processor delivers great desktop and mobile performance, low power enhancements, and multitasking for everyday computing.
Corsair 4GB (1x4GB) DDR3 1600Mhz CL11 XMS3 Performance Desktop Memory Module (CM3B4G2C1600L11B)
Corsair's mainstream memory solution for the Intel Core i3, i5 and Core i7 dual channel memory processors and platform. The XMS3 family is Corsair's mainstream line of performance DDR3 memory. These modules allow users to experience outstanding memory performance and stability. Available in Corsair's new XMS heat spreaders, each module is built using carefully selected RAMs.
  • One 4GB modules for use in high performance for the Intel Core i7, i5 and i3 Dual Channel systems
  • Outrageously fast 1600MHz performance using 4GB of memory
  • Low 11-11-11-30 latency
  • 10 Years Manufacturers Warranty
  • Density: 4GB (1x4GB Module)
  • Speed: 1600MHz
  • Timing: 11-11-11-30
  • Type: DDR3
  • Format: DIMM
  • Pin Out: 240 Pin
  • Voltage: 1.50V
Gigabyte GA-H61MA-D2V - 2.0 - motherboard - micro ATX - LGA1155 Socket - H61
Motherboard - micro ATX
Chipset Type
Intel H61 Express
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Celeron, Core i5, Core i3, Core i7, Pentium G600 series, Pentium G800 series
Max RAM Size
16 GB
RAM Supported
2 DIMM slots - DDR3 , non-ECC
Storage Ports
4 x SATA-300
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + ( 4 x USB 2.0 via headers )
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Chipset Type
Intel H61 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
1333 MHz, 1066 MHz, 800 MHz
Speed
PC3-10600, PC3-8500, PC3-6400
Supported RAM Integrity Check
Non-ECC
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111E
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 240-pin ( 1.5 V ) , 1 x PCIe 3.0 x16 , 3 x PCIe 2.0 x1
Storage Interfaces
SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices
1 x PS/2 keyboard / mouse , 1 x VGA , 1 x DVI-D , 4 x USB 2.0 , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
1 x audio , 4 x USB 2.0
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS, Hybrid EFI Technology
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage
Hardware Features
DualBIOS, Q-Flash, 3x USB Power Boost, On/Off Charge, Ultra Durable 4 Classic
Software Included
Drivers & Utilities, Norton Internet Security, @BIOS, Xpress Recovery 2, EasyTune
Plug and Play, ACPI 2.0a, Energy-Related Products (ErP) Lot 6
24.4 cm
17.4 cm
