Gigabyte Pre-Assembled Ultimate Bundle (Inc Z77-HD3, Intel Core i7-3770K & 8GB Vengeance LP Black)
Standard Due date unavailable
Exclusive Pre-Assembled Bundle: High Performance - Without The High Price Tag!
Take the fear out of Self-Build with this Gigabyte Intel Ultimate Bundle! This Bundle - which includes Motherboard, CPU & Memory - has been tested to ensure Guaranteed Compatilbity and are pre-assembled ready to use out of the box!*
Gigabyte Z77-HD3 S1155 Intel Z77 DDR3 ATX Motherboard
Gigabyte Z77-HD3 motherboard combines a host of new and exciting technologies with the latest Intel Z77 Express Chipset, creating a unique range of motherboard designs that harness the outstanding performance. With an exclusive Gigabyte 3D BIOS (dual UEFI), UD4 Classic technology and unique EZ Set Up utilities, Gigabyte Z77-HD3 motherboard ensure outstanding system absolute control, with additional features that ensure an unrivaled experience on your next PC build.
Intel Core i7-3770K S1155 3.5GHz 8MB Processor (BX80637I73770K)
With faster, intelligent, multi-core technology that applies processing power where it's needed most, Intel Core i7 processors deliver an incredible breakthrough in PC performance. They are the best desktop processors on the planet.
You'll multitask applications faster and unleash incredible digital media creation. And you'll experience maximum performance for everything you do.
Corsair 8GB (2 x 4GB) DDR3 1600Mhz CL9 Vengeance Low Profile Black Performance Desktop Memory Module (CM3B4G2C1600L9L)
Corsair Vengeance DDR3 memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
  • Capacity: 8GB (2 x 4GB Modules)
  • Speed: 1600MHz
  • Timing: 9-9-9-24
  • Type: DDR3
  • XMP: version 1.3
  • Format: DIMM
  • Pin Out: 240 Pin
  • Voltage: 1.5V
Gigabyte GA-Z77-HD3 - 1.0 - motherboard - ATX - LGA1155 Socket - Z77
Motherboard - ATX
Chipset Type
Intel Z77 Express
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
DDR3 , non-ECC
Storage Ports
2 x SATA-600 (RAID), 4 x SATA-300 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + ( 2 x USB 3.0 + 4 x USB 2.0 via headers )
HD Audio (8-channel)
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel Z77 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
Supported RAM
Max Size
32 GB
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
Supported RAM Integrity Check
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio Codec
Realtek ALC887
High Definition Audio
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin ( 1.5 V ) , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x16 ( x4 mode ) , 2 x PCIe 2.0 x1 , 2 x PCI
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
1 x PS/2 keyboard / mouse , 4 x USB 2.0 , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DVI-D , 1 x HDMI , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK , 1 x microphone - mini-jack
Internal Interfaces
2 x USB 3.0 , 4 x USB 2.0 , 1 x SPDIF out , 1 x audio
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
DMI 2.0 support, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
Hardware Features
DualBIOS, Q-Flash, GIGABYTE eXtreme Hard Drive (XHD), AutoGreen, Intel Extreme Memory Profile (XMP) support, On/Off Charge, GIGABYTE 333 Onboard Acceleration, Ultra Durable 4 Classic, AMD CrossFireX technology support, Intel Rapid Start Technology, GIGABYTE LAN Optimizer
Software Included
Norton Internet Security, @BIOS, Q-Share, GIGABYTE EZ Smart Response, GIGABYTE 3D Power, GIGABYTE EZ Setup
Plug and Play, ACPI 2.0a
30.5 cm
21.5 cm
Scroll to top
