BT.com
Wishlist
Gigabyte MINI-ITX I DIMM GbE SATA
£419.37
£419.37
Add to wishlist
Delivery
Standard Due date unavailable
The GA-9SISL delivers advanced performance on a platform including all the features required to be an optimal choice for light and scalable server applications. In addition to the excellent computing power and energy consumption ratio the GA-9SISL features DIMM and PCIe slots for additional storage or network features Gigabit LAN ports for flexible network configurations as well as board placement, optimized for rackmount integration. This combination of features makes the GA-9SISL a great solution to build microservers, lightweight redundant configurations, web hosting arrays, network appliances and much more.
Gigabyte GA-9SISL - 1.0 - motherboard - mini ITX - Intel Atom C2750
Motherboard - mini ITX
Intel Atom C2750 / 2.4 GHz ( 8-core )
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC, ECC , unbuffered
Storage Ports
2 x SATA-600, 4 x SATA-300
USB / FireWire Ports
2 x USB 2.0
Graphics
ASPEED AST2400
LAN
4 x Gigabit Ethernet
Cache Memory
L2 - 4 MB
Supported RAM
Max Size
64 GB
DDR3
Bus Clock
1600 MHz
Supported RAM Integrity Check
Non-ECC, ECC
Registered or Buffered
Unbuffered
Single rank, dual rank
Graphics
Graphics Controller
ASPEED AST2400
LAN
Network Interfaces
Expansion Slots
4 x DIMM 240-pin ( 1.5 V/ 1.35 V ) , 1 x PCIe 2.0 x16
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices
2 x USB 2.0 , 1 x VGA , 1 x management , 4 x LAN (Gigabit Ethernet) , 1 x serial
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
IPMI 2.0 support
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage
Hardware Features
Clear CMOS Button
I/O back plate
2 x Serial ATA cable
17 cm
17 cm
Scroll to top
