BT.com
Wishlist
Gigabyte Mainboard ATX DIMM 10Gbe
£654.54
£654.54
Add to wishlist
Delivery
Standard Due date unavailable
Based on the Haswell microarchitecture, these Intel processor families bring a whole set of performance boosting features. In addition to the usual boost in frequencies and core numbers, the Intel Xeon E5-1600/2600 V3 families are the first in the industry to support the brand DDR4 memory technology. Moreover, these processor include encryption performance overhead reduction features, and technologies improving run time and migration VM integrity.
The Intel Xeon E5-1600/2600 V3 families are the first generation of processor to support exclusively the DDR4 technology on the market.
Gigabyte MD70-HB0 - 1.2 - motherboard - extended ATX / SSI EEB - LGA2011-v3 Socket - C612
Motherboard - extended ATX / SSI EEB
Chipset Type
Intel C612
Processor Socket
2 x LGA2011-v3 Socket
Compatible Processors
Xeon E5-2600 v3 series, Xeon E5-1600 v3 series
Max RAM Size
1 TB
RAM Supported
16 DIMM slots - DDR4, ECC, registered, Load-Reduced
Storage Ports
8 x SAS3 (RAID), 10 x SATA-600 (RAID)
USB / FireWire Ports
3 x USB 3.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
Graphics
ASPEED AST2400
LAN
2 x 10 Gigabit Ethernet
Chipset Type
Intel C612
Processor Socket
LGA2011-v3 Socket
Max Processors Qty
2
Supported RAM
Max Size
1 TB
DDR4
Bus Clock
1600 MHz, 1866 MHz, 2133 MHz
Supported RAM Integrity Check
ECC
Registered or Buffered
Registered, Load-Reduced
Single rank, dual rank, quad channel memory architecture, quad rank
Details
512 GB - registered - ECC , 1 TB - Load-Reduced - ECC
Graphics
Graphics Controller
ASPEED AST2400
LAN
Network Controller
Intel X540
Network Interfaces
Expansion Slots
2 x CPU , 16 x DIMM 288-pin (1.2 V) , 3 x PCIe 3.0 x16 , 1 x PCIe 2.0 x8 (x4 mode)
Storage Interfaces
LSI Logic LSISAS3008: SAS 3 - 8 devices - RAID 0 / RAID 1 / RAID 1E / RAID 10 , SATA-600 -connectors: 10 x 7pin SATA - 10 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
1 x serial , 1 x VGA , 2 x LAN (10Gigabit Ethernet) , 1 x management , 2 x USB 3.0
Internal Interfaces
2 x USB 2.0 - header , 1 x serial - header , 1 x USB 3.0 - Type A , 2 x USB 3.0 - header
Power Connectors
24-pin main power connector, 2 x 8-pin ATX12V connectors
BIOS Features
iKVM support, IPMI 2.0 support
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU core voltage
Hardware Features
All IR digital power design, square ILM
30.5 cm
33 cm
Scroll to top
