BT.com
Wishlist
Gigabyte M6900 Optical Gaming Mouse - 7 button - USB - black
Gigabyte M6900 Optical Gaming Mouse...
£18.02
Top Selling Gigabyte Gaming Mouse!
8 in stock
£18.02
Add to wishlist
Delivery
Standard 3-5 working days
Precision Optical Gaming Mouse
On-the-fly DPI Switching with LED display
3 stage DPI indicator (default 800dpi/1600dpi/2000dpi) (customizable 400~3200dpi adjustment via software)
GIGABYTE FORCE application
Simple drag-down menu enables user to set up mouse function depending on personal requirement
Gaming-grade Rubber
Comfortable texture with sweat-proof design provides a non-slip grip.
Gold-plated USB connector
1.8m strengthened cable customized for professional gamer
4 way tilt-wheel scrolling provides more functionality and more application
Highlights
3200dpi precise optical sensor
30G acceleration ensures the best performance during rapid movements
On-the-fly DPI switching with 3 stage red LED light indicator
Gaming-grade rubber provides a non-slip grip
Gigabyte M6900 - mouse - USB - black
Mouse
Wired - USB
7.8 cm x 12.5 cm x 4.2 cm
106 g
Movement Detection Technology
Optical
Buttons Qty
7
Movement Resolution
3200 dpi
Performance
30 G maximum acceleration, up to 65 inches per second, realtime sensitivity switching 800/1600/3200 dpi, 3600 fps
Scrolling wheel (4-way), golden USB plug, on-the-fly DPI switching with 3 stage red LED light indicator, gaming-grade rubber
1 x USB cable - integrated - 1.8 m
Microsoft Windows 98/2000/ME/XP/Vista/7
Mouse
7.8 cm
12.5 cm
4.2 cm
106 g
Input Device
Wired
USB
Optical
Buttons Qty
7
Movement Resolution
3200 dpi
Performance
1 x USB - 4 pin USB Type A
BSMI, FCC
Software Included
Drivers & Utilities
Other bundles
Gigabyte M6900 Optical Gaming Mouse - 7 button - USB -...
£18.02
Save on Intenso 32GB USB Drive
Save £1.48
£22.52
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Great mouse
Reviewed by Luke on 02/04/2015
As I was building a new gaming PC, on a budget. I decided this mouse, was just right for my needs (considering I was using a very standard dell mouse before) This mouse does everything I need, its super sensitive (in a good way) very nice gliding notion on the mouse mat. Looks great and feels great in my hand. I could have bought it for £13 if I had of been 1 day earlier, so unfortunately got it for £18 (which is still a great price for this product, and would love to know why there are mice which are so much more expensive)
Scroll to top
