Click to visit BT.com
BT.com
Wishlist
Gigabyte Intel 4th Gen Pre-Assembled Ultimate Bundle (Z87-HD3, Core i5-4670K & 8GB Vengeance Pro)
4.0*
Quicklinx: 8QHDWS00
Mfr#: GBTINTEL-ULTIMATE2
Essential accessories
Exclusive Pre-Assembled Bundle: High Performance - Without The High Price Tag!
Perfect Gaming PC on the Z87 Platform - with Brand New Intel 4th Generation Core i5 Processor!
Take the fear out of Self-Build with this Gigabyte Intel Ultimate Bundle! This Bundle - which includes Motherboard, CPU & Memory - has been tested to ensure Guaranteed Compatilbity and are pre-assembled ready to use out of the box!*
Gigabyte Z87-HD3 Intel Motherboard
  • Supports 4th Generation Intel® Core™ processors
  • GIGABYTE Ultra Durable™ 4 Plus Technology
  • GIGABYTE UEFI DualBIOS™
  • 15µ gold plated CPU socket
  • Multi-GPU Support
  • All solid capacitors
  • GIGABYTE On/Off Charge™ for USB devices
  • Intel® LAN with high ESD Protection
Ultra Safe: GIGABYTE UEFI DualBIOS™
GIGABYTE motherboards feature GIGABYTE DualBIOS™, an exclusive technology from GIGABYTE that protects arguably one of your PC's most crucial components, the BIOS. GIGABYTE DualBIOS™ means that your motherboard has both a 'Main BIOS' and a 'Backup BIOS', making users protected from BIOS failure due to virus attack, hardware malfunction, improper OC settings or power failure during the update process.
High ESD Protection for USB and LAN
GIGABYTE 8 Series motherboards raise the bar in terms of protecting your system, providing advanced electrostatic discharge (ESD) protection for both your Ethernet LAN and USB ports, both common sources of ESD-related failures. Each LAN and USB port is paired with a dedicated protection filter that can withstand high electrostatic discharges, protecting your system from common electrical surges and even direct lighting strikes.
Gold Plated CPU Socket
GIGABYTE 8 Series motherboards come equipped with a gold plated CPU socket, which means that enthusiasts can enjoy absolute reliability and longevity for the CPU socket overtime, without having any concerns about corroded pins and bad contacts.
One Fuse per USB Port
On GIGABYTE 8 Series motherboards each USB port has its own dedicated power fuse that prevents unwanted USB port failure, helping to safe guard your important data during transfer.
Intel® LGA1150 4th Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors Ready
GIGABYTE 8 Series motherboards support the latest 4th Generation Intel® Core™ processors, bringing together a unique blend of features and technologies that offer the absolute ultimate platform for your next PC build. From high current capable digital power delivery, performance-enhancing caching technologies, exclusive high-end audio features, advanced networking and device charging, gold plated hardware connectors and of course, killer good looks, GIGABYTE 8 series motherboards are in a class of their own.
The latest Intel 8 Series platform offers significant improvements in performance and power consumption with the latest 4th generation Intel® Core™ processors and Intel® Z87 chipsets. As well as a boost in overall productivity, the latest HD4600 Intel® processor graphics provide native 4K resolution playback over standard HDMI connectivity, with significantly higher frame rates in the latest DX11 3D game titles.
GIGABYTE Ultra Durable™ 4 Plus debuts on GIGABYTE 8 Series motherboards, with a range of features and component choices that provide record-breaking performance, cool and efficient operation and extended motherboard lifespan. GIGABYTE motherboards feature new heatsink designs that offer uncompromisingly efficient cooling on key areas of the motherboard including the PWM area and chipset (PCH). GIGABYTE 8 Series motherboards offer both passive, active and water cooling support of the crucial PWM area so even the most aggressive and extreme configurations will be kept well within optimal thermal parameters.
Multi-display support with AMD CrossFire™
AMD CrossFire™ delivers the ultimate graphics performance for gaming enthusiasts who demand the highest frame rates without compromising on resolution.
Intel Core i5-4670K S1150 3.4GHz 6MB Haswell Quad Core Processor Unlocked (BX80646I54670K)
Amazing performance and stunning visuals with a boost. Raise the bar on your PC experience with rich visuals plus an automatic burst of speed when you need it1 (with Intel® Turbo Boost Technology), featuring a 4th generation Intel® Core™ i5 processor with longer battery life41 and built-in security for deeper protection.
As our most popular family member, the 4th generation Intel® Core™ i5 processor delivers amazing performance, stunning visuals, and built-in security for deeper protection.8 Enjoy the thrill of an automatic burst of speed when you need it with Intel® Turbo Boost Technology 2.0.1 Experience your movies, photos, and games smoothly and seamlessly with a suite of visual enhancements built into the processor3--and do it all longer with improved battery life.41 Get a boost in your performance that you can truly see and feel--all while enjoying the peace of mind from enhanced security. Because the only thing more amazing than Intel® technology is what you'll do with it.
Make the 4th generation Intel® Core™ processor the processor of choice for your PC.
  • Intel® Turbo Boost Technology 2.0
  • Intel® Hyper-Threading Technology
  • Even better battery life
  • Sharper built-in visuals
  • Intel® Clear Video HD Technology
  • Intel® HD Graphics
  • Built-in security for deeper protection
Corsair 8GB (2 x 4GB) Vengeance Pro Blue DDR3 1600MHz CL9 Memory (CMY8GX3M2A1600C9B)
Corsair Vengeance Pro Series memory modules are designed for overclocking on the latest 3rd and 4th generation Intel® Core™ platforms, with eight-layer PCBs and ICs specially selected for performance potential. The aluminum heat spreaders provide superior temperature management and have the aggressive look you want in your gaming rig. XMP 1.3 profiles allow for automatic, reliable overclocking.
Gigabyte GA-Z87-HD3 - 1.0 - motherboard - ATX - LGA1150 Socket - Z87
Motherboard - ATX
Chipset Type
Intel Z87 Express
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7, Xeon E3-1200 series
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3 , non-ECC
Storage Ports
6 x SATA-600 (RAID)
USB / FireWire Ports
4 x USB 3.0 + 2 x USB 2.0 + ( 2 x USB 3.0 + 6 x USB 2.0 via headers )
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Motherboard - ATX
Chipset Type
Intel Z87 Express
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 2933 MHz
Supported RAM Integrity Check
Non-ECC
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1 GB
Audio
Audio Codec
Realtek ALC892
High Definition Audio
LAN
Network Controller
Realtek RTL8111F-VL
Network Interfaces
Gigabit Ethernet
Expansion Slots
4 x DIMM 240-pin ( 1.5 V ) , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x16 ( x4 mode ) , 2 x PCIe 2.0 x1 , 2 x PCI , 1 x CPU
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Smart Response Technology
2 x USB 2.0 , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.0 , 1 x DVI-D , 1 x VGA , 1 x PS/2 keyboard / mouse , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack
Internal Interfaces
6 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x serial - header , 1 x parallel - header , 1 x audio - header , 1 x SPDIF in - header , 1 x SPDIF out - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection, CPU core voltage
Hardware Features
DualBIOS, Q-Flash, All-Solid Capacitor motherboard Design, ASUS Smart Fan II, Intel Extreme Memory Profile (XMP) support, On/Off Charge, Intel Smart Response Technology, One Port One Fuse, AMD CrossFireX technology support, Intel Rapid Start Technology, Intel Smart Connect Technology, ESD Protection, Ultra Durable 4 Plus
Software Included
Norton Internet Security, @BIOS, EasyTune, GIGABYTE EZ Setup, Xpress Install, GIGABYTE USB Blocker, GIGABYTE App Center
Plug and Play, ACPI 2.0a
30.5 cm
22.5 cm
Customer reviews
Write a review for the Gigabyte Intel 4th Gen Pre-Assembled Ultimate Bundle (Z87-HD3, Core i5-4670K & 8GB Vengeance Pro) here!
Response for Nick B.
Reviewed by Anonymous Review Posted 10/09/2013
Nick B...
1. How is this a product review?
2. Had you looked under the 'Specifications' tab, you would have found your answer.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Customer reviews for the Gigabyte Intel 4th Gen Pre-Assembled Ultimate Bundle (Z87-HD3, Core i5-4670
Reviewed by Nick B. Review Posted 03/08/2013
It doesn't say if the board is ATX or mATX so you cannot select a case!!!
  • Overall 3*
  • Ease of use 3*
  • Value for money 2*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
