BT.com
Wishlist
Gigabyte H77N-WIFI S1155 Intel H77 DDR3 mITX
Delivery
Standard Due date unavailable
New 3rd generation Intel® Core™ processors are based on the new 3rd generation Intel® Core™ processor architecture, manufactured using the latest 22nm process to create a visually optimized processor platform. Based on the mature LGA 1155 socket, 3rd generation Intel® Core™ processors feature up to four high-performance 64-bit processor cores and 8MB of L3 cache Smart Cache, and overall performance when you need it most.
Designed for PCI Express Gen.3 Support
GIGABYTE 7 series motherboards take advantage of the latest connectivity and expansion bus technologies available on the Intel platform. The 3rd generation Intel® Core™ processor platform debuts the new PCI Express gen. 3.0 expansion bus, allowing users to take advantage of the next generation, high-bandwidth discrete graphics card solutions. * PCIE Gen.3 is dependent on CPU and expansion card compatibility.
Intel® Rapid Start Technology
Intel® Rapid Start Technology™ gets your device up and running faster from even the deepest sleep. This means users will be able to experience almost zero power draw from their PC, but be able to resume Windows® 7 is a few seconds without having the PC go through a full system boot. With Intel® Rapid Start Technology the previous session resumes to the exact as it was, so that applications are still in the same state and no application data is lost.
Support Intel Wireless Display (Intel WiDi)
Intel Wireless Display let you enjoy wireless life at home and at work. Through adapters, you can easily experience your PC on you TV or projectors, Broadcasting Promotion and commercials with more flexibility and efficiency.
Support Intel Wi-Fi Technology-Intel® My WiFi Dashboard
Intel My WiFi Dashboard provides ultimate portability, and puts you in control of your own personal area network. You can connect, communicate and collaborate with others without joining a home, office or hotspot network.
Exclusive Bluetooth 4.0/WiFi module
The motherboard integrates an exclusive PCIe module that offers support for the latest Bluetooth 4.0 and IEEE 802.11 b/g/n Wi-Fi connectivity. The Bluetooth 4.0 standard includes Smart Ready technology that is debuting on mobile devices including the Apple® iPhone® 4s. This means that transferring important content from your smart phone or tablet is easier and faster than ever.
Gigabyte GA-H77N-WIFI - 1.0 - motherboard - mini ITX - LGA1155 Socket - H77
Motherboard - mini ITX
Chipset Type
Intel H77 Express
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Celeron, Core i5, Core i3, Core i7, Pentium G600 series, Pentium G800 series, Xeon E3-1200 series
Max RAM Size
16 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC
Storage Ports
2 x SATA-600 (RAID), 2 x SATA-300 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
802.11b/g/n, Bluetooth, 2 x Gigabit Ethernet
Chipset Type
Intel H77 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 800 MHz
Supported RAM Integrity Check
Non-ECC
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
Audio Codec
Realtek ALC892
High Definition Audio, Dolby Home Theater
LAN
Network Interfaces
Expansion Slots
1 x CPU , 2 x DIMM 240-pin (1.5 V) , 1 x PCIe 3.0 x16
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Smart Response Technology
1 x PS/2 keyboard / mouse , 1 x DVI-D , 2 x HDMI , 4 x USB 2.0 , 2 x USB 3.0 , 2 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x TOSLINK
Internal Interfaces
1 x audio - header , 1 x SPDIF out - header , 2 x USB 2.0 , 2 x USB 3.0 , 1 x serial - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS, GIGABYTE 3D BIOS
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage
Hardware Features
DualBIOS, Q-Flash, GIGABYTE eXtreme Hard Drive (XHD), AutoGreen, 3x USB Power Boost, On/Off Charge, Intel Smart Response Technology, Ultra Durable 4 Classic, Intel Rapid Start Technology, Intel Smart Connect Technology, Intel Quick Sync Video 2.0, Intel Wireless Display (WiDi), Intel My WiFi Dashboard
Software Included
Norton Internet Security, @BIOS, Q-Share, EasyTune, GIGABYTE EZ Smart Response, GIGABYTE EZ Setup, Xpress Install
Plug and Play, ACPI 2.0a, Energy-Related Products (ErP) Lot 6
17 cm
17 cm
Scroll to top
