BT.com
Wishlist
Gigabyte H61N-USB3 S1155 Intel H61 DDR3 mITX
Delivery
Standard Due date unavailable
Gigabyte Super4 motherboard is the desktop motherboard based on the Intel H61 express chipset. Not only delivering Intel's industry-leading performance and advanced integrated graphics capabilities, Gigabyte Super4 motherboard is equipped with a comprehensive range of unique features that offer mainstream PC users the most compelling platform on the market today.
Gigabyte Super4 motherboard boasts specific features that guard against system malfunction and ensure extended system longevity, including Gigabyte DualBIOS to ensure that you never experience system failure due to BIOS corruption. Additionally, each USB port has its own dedicated power fuse that prevents unwanted USB port failure, helping to safe guard your important data during transfer.
Gigabyte 6 series motherboard incorporates an Intel approved Intersil PWM controller that is VRD 12 (Voltage Regulator Down) compliant. This means that it offers features that include SerialVID (SVID) which transfers power management information between the processor and voltage regulator controller, allowing more robust and efficient signaling control between the CPU and PWM controller - hence, delivering a more energy efficient platform.
Gigabyte GA-H61N-USB3 - 1.0 - motherboard - mini ITX - LGA1155 Socket - H61
Motherboard - mini ITX
Chipset Type
Intel H61 Express
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
16 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC
Storage Ports
2 x SATA-300, 1 x eSATA-300
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + (4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Chipset Type
Intel H61 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
1333 MHz, 1066 MHz, 800 MHz
Speed
PC3-10600, PC3-8500, PC3-6400
Supported RAM Integrity Check
Non-ECC
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC889
High Definition Audio
LAN
Network Controller
Realtek RTL8111E
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 240-pin (1.5 V) , 1 x PCIe x16
Storage Interfaces
SATA-300 -connectors: 2 x 7pin Serial ATA - 2 devices , SATA-300 -connectors: 1 x 7pin external SATA - 1 devices
1 x TOSLINK , 1 x SPDIF out , 1 x VGA , 1 x DVI-D , 1 x HDMI , 4 x USB 2.0 , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
1 x SPDIF out , 4 x USB 2.0
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
Award
BIOS Features
DMI 2.0 support, ACPI 1.0b support, SMBIOS 2.4 support, Hybrid EFI Technology, Touch BIOS, Xpress BIOS Rescue
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage
Hardware Features
DualBIOS, Q-Flash, Trusted Platform Module (TPM), Smart 6, GIGABYTE Dynamic Energy Saver (DES) 2, AutoGreen, 3x USB Power Boost, Ultra Durable 2, On/Off Charge, Voltage Regulator Down 12 (VRD) compliant, GIGABYTE Super4
Software Included
Norton Internet Security, @BIOS, Xpress Recovery 2, Q-Share, Cloud OC, EasyTune
Plug and Play, ACPI 1.0b, Energy-Related Products (ErP) Lot 6
17 cm
17 cm
Scroll to top
