BT.com
Wishlist
Gigabyte H61M-D3V S1155 Intel H61 DDR3 ATX
Delivery
Standard Due date unavailable
The Gigabyte motherboard is fully configured to provide gamers with the generation 3 PCI Express technology, delivering maximum data bandwidth for forthcoming discrete graphics cards.
Gigabyte ultra durable motherboard is equipped with solid capacitors developed by leading Japanese manufacturers. With an average lifespan of 50,000 hours, these solid capacitors provide the stability, reliability and longevity essential to meet the power needs of high-end processors and other components running today's most demanding applications and games...
Gigabyte GA-H61MA-D3V - 2.0 - motherboard - micro ATX - LGA1155 Socket - H61
Motherboard - micro ATX
Chipset Type
Intel H61 Express
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Celeron, Core i5, Core i3, Core i7, Pentium G600 series, Pentium G800 series
Max RAM Size
16 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC
Storage Ports
2 x SATA-600 (RAID), 4 x SATA-300
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + (4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Chipset Type
Intel H61 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
1333 MHz, 1066 MHz, 800 MHz
Speed
PC3-10600, PC3-8500, PC3-6400
Supported RAM Integrity Check
Non-ECC
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111E
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 240-pin (1.5 V) , 1 x PCIe 3.0 x16 , 3 x PCIe 2.0 x1
Storage Interfaces
SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices , Marvell 88SE9172: SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1
1 x PS/2 keyboard / mouse , 1 x VGA , 1 x DVI-D , 4 x USB 2.0 , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
1 x audio , 4 x USB 2.0
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS, Hybrid EFI Technology
Hardware Monitoring
CPU core temperature, chassis temperature, CPU fan tachometer, chassis fan tachometer, system voltage, CPU overheating protection
Hardware Features
DualBIOS, Q-Flash, 3x USB Power Boost, On/Off Charge, Ultra Durable 4 Classic
Software Included
Drivers & Utilities, Norton Internet Security, @BIOS, Xpress Recovery 2, EasyTune
Plug and Play, ACPI 2.0a, Energy-Related Products (ErP) Lot 6
24.4 cm
17.4 cm
Scroll to top
