Click to visit BT.com
BT.com
Wishlist
Gigabyte GZ-G2 Gaming Case with 2 Front Fans
5.0*
Quicklinx: 7YWLWS00
Mfr#: GIGA-GZ-G2
New Gaming Case from Gigabyte for 2012
  • GZ-G2 with 2 x 120mm front Cooling fans
  • Side panel with Intel Tac 2.0 ventilation holes to support 2 x 120mm fans
  • Control on/off button for fans on front of case
  • Multi media panel located at the front middle for easy access with reset button
  • Tool-less installation for 5.25 / 3.5 Devices
  • 80mm rear exhaust fan
  • Water cooling holes for future upgradability for liquid cooling
  • Convex side panel at the back of motherboard for hiding extra cables
  • Space for 2 x 120mm case fans on side panel
  • Power supply positioned at bottom
  • Ventilation holes and dust filter for PSU
  • Black coated interior
  • Pedestal foots provide stability and protect floor from scratches
Specification
  • Model no. GZ-G2
  • Dimensions ( W x H x D ) 185 x 420 x 445 mm
  • Material ABS / Mesh/ 0.6 mm SGCC
  • Color (s) Black
  • Side panel (s) TAC 2.0
  • Drive bays 5.25" x1 , 3.5"x1 +6(internal)
  • Expansion slots 7
  • Form factor ATX / Micro ATX
  • I / O ports 2 x USB 2.0 / 1 x HD Audio
  • Fans Front: 120mm silent fan x 2 (w/ fan switch x 2)
  • Rear: 80mm silent fan x1
  • Weight 5.25kg
Case Form Factor
Mid tower
Motherboard Form Factor
ATX/MicroATX
Power Supply
None
Customer reviews
Write a review for the Gigabyte GZ-G2 Gaming Case with 2 Front Fans here!
Very nice case for the money.
Reviewed by Sam. Review Posted 01/10/2012
Bought this case for a new PC build, it's very good quality. All the parts are well designed and the fittings are well thought out, making it very easy to install hardware.
The two front fans are very quiet and effective, with side ports for another two 120mm's this case should have no airflow problems.
Only downside would be that it has room for just a single dvd drive, this was not an issue for me though.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Excellent Case For The Price
Reviewed by Mark. Review Posted 08/02/2014
I brought this case a while back for a new computer build which was indeed for a gaming case. I have just placed another order for one of these cases even though really I did not need it, I have an Antec 900 case and I need extra hard drive space but the 900 does not give much scope. This will hold about 7 or 8 hard drives comfortably. The only tip that I can give you when building a system using this case, is to put the DVD drive or Blu Ray drive in first. I made the mistake of doing the mobo first and then I was stuck for the space to get the Blu Ray into.
  • Overall 5*
  • Ease of use 5*
Design fault leaves hot spots in case.
Reviewed by Sam. Review Posted 26/08/2013
I previously reviewed this case and gave it 5 stars, but having used it a while I discovered it has a serious design flaw. The small 80mm exhaust fan is not adequate, and this leads to a hot spot at the top and right side of the case.
Gigabyte obviously noticed this problem, as the newer version has another 120mm fan in the top, sadly they are still selling this one as a 'gaming' case, which I feel is misleading as gaming rigs generally need very good airflow which this case should have, but sadly doesn't.
  • Overall 3*
  • Ease of use 5*
  • Value for money 4*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
