BT.com
Wishlist
Gigabyte GeForce GTX 950 XTREME 2GB GDDR5 PCIe3.0 DX12
Delivery
Standard Due date unavailable
The GTX 950 Xtreme Gaming graphics card is the first of many gamer-focused products that GIGABYTE will be rolling out this year. This graphics card is built upon the Super Overclock GPU along with the well-acclaimed WINDFORCE cooling solution featuring 3D-Active Fan to deliver the finest gaming experience and silent cooling performance in the same category.
Gigabyte GV-N950XTREME-2GD - graphics card - GF GTX 950 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 950
2 GB GDDR5
Core Clock
1203 MHz
Boost Clock
1405 MHz
Effective Memory Clock
7 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
DVI-I (dual link) , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
4.2 cm x 24 cm x 13.2 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1203 MHz
Boost Clock
1405 MHz
Process Technology
28 nm
Max Resolution
4096 x 2160
4
API Supported
Ultra Durable VGA, LED indicator, Extreme Cooler, GIGABYTE GPU Gauntlet Sorting, MSI Solid Capacitor, Nvidia 3D Vision technology, GIGABYTE WindForce 2x, Dual Fan Design, OC Guru II
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
7 GHz
Bus Width
128-bit
Required Power Supply
350 W
Additional Requirements
8 pin PCI Express power connector
Software Included
OC Guru ll
4.2 cm
24 cm
13.2 cm
Scroll to top
