BT.com
Wishlist
Gigabyte GeForce GTX 780 954MHz 3GB PCI-Express 3.0 HDMI Windforce 3X OC
Delivery
Standard Due date unavailable
OC GURU ll
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up MONITORING, GPU CLOCK, MEMORY CLOCK, FAN, GPU VOLTAGE, Memory VOLTAGE, OSD, ONLINE SUPPORT and update driver, BIOS directly.
NEW WINDFORCE 3X 2 SLOT 450W cooling system
Keeping the same 450W Cooling capacity using only 2 slots, the New WINDFORCE 3X 450W cooling system is equipped with two 8mm and four 6mm cooper heat-pipes , inclined fans, and GIGABYTE "Triangle Cool" technology. This not only provides an effective heat dissipation capacity but GPU Boost 2.0 technology also enables higher performance due to a lower temperature.
Up to 4 displays on a Single Card
In the Kepler architecture, support up to four displays on a single card. Satisfy your mulit-screen steup, high definition and extreme gaming experience.
  • WINDFORCE 3X 450W Cooling system
  • Powered by NVIDIA GeForce GTX 780 GPU
  • Integrated with industry's best 3GB GDDR5 memory 384-bit memory interface
  • Features Dual-link DVI-I/ DVI-D / HDMI / DisplayPort
  • BASE:954MHz / BOOST:1006 MHz
  • System power supply requirement: 600W
  • Model name GV-N780OC-3GD
  • Core Clock (MHz) Base: 954MHz Boost: 1006MHz
  • Stream Processor 2304
  • Mem Clock (MHz) 6008MHz
  • Mem Size 3072MB
  • Mem Bus (bit) 384 bit
  • Mem Type 64Mx32 GDDR5
  • Memory (pcs) 12
  • I/O Dual link DVI-I / DV-D HDMI x1 Displayport
  • DirectX OpenGL DirectX 11.1 OpenGL 4.3
  • Card Interface PCI Express 3.0
  • Board Form ATX 2 slot
  • Fan/Heat Sink WIINDFORCE 3X 2 slot 450W with "Triangle Cool"
Gigabyte GV-N780OC-3GD graphics card - GF GTX 780 - 3 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
3 GB GDDR5
Core Clock
954 MHz
Boost Clock
1006 MHz
Effective Memory Clock
6.008 GHz
Memory Interface
384-bit
Max Resolution
2560 x 1600
Max Resolution Details
DVI: 2560 x 1600 / VGA: 2048 x 1536
Max Monitors Supported
4
DVI-I (dual link) , DVI-D , HDMI , DisplayPort
API Supported
OpenGL 4.3
4.3 cm x 29.2 cm x 12.9 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
954 MHz
Boost Clock
1006 MHz
Process Technology
28 nm
Max Resolution
2560 x 1600
4
API Supported
OpenGL 4.3
Dual Slot Fan Cooler, Nvidia PhysX-Ready, Nvidia 3D Vision technology, GIGABYTE WindForce 3x, Nvidia SLI ready, Triangle Cool Technology, NVIDIA Adaptive Vertical Sync, Kepler GPU Architecture, OC Guru II, NVIDIA GPU Boost 2.0
Size
3 GB
GDDR5 SDRAM
Effective Clock Speed
6.008 GHz
Bus Width
384-bit
Required Power Supply
600 W
4.3 cm
29.2 cm
12.9 cm
Scroll to top
