BT.com
Wishlist
Gigabyte GeForce GTX 760 2GB PCI-Express 3.0 HDMI OC Windforce 450W
Delivery
Standard Due date unavailable
Key Features
  • OC to 1085 MHz (Std : 980 MHz)
  • GPU Boost 2.0 by NVIDIA
  • Support up to 4 displays at single card and Maximum 4K resolutions
  • WINDFORCE 3X cooling design (with "Triangle Cool" technology)
  • Direct Heat Pipe touch technology(DHT)
  • Model name GV-N760OC-2GD
  • GPU GTX 760
  • Core Clock (MHz) Base: 1085MHz (std 980 MHz) Boost: 1150MHz (std 1033 MHz)
  • Stream Processor 1152
  • Mem Clock (MHz) 6008MHz
  • Mem Size 2048MB
  • Mem Bus (bit) 256 bit
  • Mem Type 64Mx32 GDDR5
  • I/O Dual link DVI-I / DV-D HDMI x1 Displayport
  • DirectX OpenGL DirectX 11.1 OpenGL 4.3
  • Card Interface PCI Express 3.0
  • Board Form ATX 2 slot
  • Fan/Heat Sink WINDFORCE 3X with "Trangle Cool"
  • Tools OC Guru II
  • System PSU Limitation 500W
  • Card Size H=43,L=275, W=136.6 mm
Gigabyte GV-N760OC-2GD - graphics card - GF GTX 760 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 760
2 GB GDDR5
Core Clock
1085 MHz
Boost Clock
1150 MHz
Effective Memory Clock
6.008 GHz
Memory Interface
256-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
DisplayPort , HDMI , DVI-I (dual link) , DVI-D
API Supported
DirectX 11.1, OpenGL 4.3
4.3 cm x 27.5 cm x 13.66 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1085 MHz
Boost Clock
1150 MHz
Process Technology
28 nm
Max Resolution
4096 x 2160
4
API Supported
Ultra Durable VGA, Nvidia PhysX-Ready, Nvidia 3D Vision technology, GIGABYTE WindForce 3x, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost, OC Guru II
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6.008 GHz
Bus Width
256-bit
Required Power Supply
500 W
Software Included
OC Guru ll
4.3 cm
27.5 cm
13.66 cm
Scroll to top
