BT.com
Wishlist
Gigabyte GeForce GTX 750 Ti OC 4GB GDDR5 PCIe3.0 WINDFORCE 2X
Gigabyte GeForce GTX 750 Ti OC 4GB...
£125.84
£125.84
Add to wishlist
Delivery
Standard Due date unavailable
Gigabyte introduces Windforce, the latest cooling technology that differentiates the brand's graphics cards from the rest. Gigabyte understands that a fan is crucial to the graphics card, so only the fan with the most efficiency is selected for Windforce.
The airflow is spilt through the triangle design at the fan edge, and is guided smoothly through the fan by special 3D stripe curve design. At the same time, it effectively enhanced the cooling capacity while reducing air turbulence.
Support up to four displays on a single card. Satisfy your multi-screen setup, high definition and extreme gaming experience.
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections. Dual HDMI design lets users experience broader, richer gaming environments with better resolution on a single card.
Intuitive user interface helps you easily modify important settings and directly update driver and BIOS. Clock speeds, voltage, fan performance, and OSD setting can be monitored and tuned in real-time according to your own preference.
Gigabyte GV-N75TWF2OC-4GI - OC Edition - graphics card - GF GTX 750 Ti - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 750 Ti
4 GB GDDR5
Core Clock
1059 MHz
Boost Clock
1137 MHz
Effective Memory Clock
5.4 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
DVI-I (dual link) , DVI-D (dual link) , 2 x HDMI
API Supported
OpenGL 4.4, DirectX 12
4.2 cm x 19.7 cm x 12.7 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1059 MHz
Boost Clock
1137 MHz
Process Technology
28 nm
Max Resolution
4096 x 2160
4
API Supported
Ultra Durable 2, GIGABYTE WindForce 2x, Gold plated HDMI, OC Guru II
Size
4 GB
GDDR5 SDRAM
Effective Clock Speed
5.4 GHz
Bus Width
128-bit
Required Power Supply
400 W
Additional Requirements
6 pin PCI Express power connector
Software Included
OC Guru ll
4.2 cm
19.7 cm
12.7 cm
Scroll to top
