BT.com
Wishlist
Gigabyte GeForce GTX 750 Ti OC 1GB GDDR5 PCIe3.0 Graphics Card
1 on order, no confirmed delivery date
Delivery
Standard Due date unavailable
As opposed to the stereotype, GIGABYTE is able to maximize fan size to 10cm with the latest cooling design. With a 10cm fan, the card is virtually silent that its noise level runs much lower. The airflow is split through the triangle design at the fan edge, and is guided smoothly through the fan by special 3D stripe curve design. At the same time, it effectively enhanced the cooling capacity while reducing air turbulence.
Gigabyte GV-N75TOC-1GI (rev. 1.0) - OC Edition - graphics card - GF GTX 750 Ti - 1 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 750 Ti
1 GB GDDR5
Core Clock
1033 MHz
Boost Clock
1111 MHz
Effective Memory Clock
5.4 GHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Monitors Supported
4
DVI-I (dual link) , DVI-D (dual link) , 2 x HDMI
API Supported
OpenGL 4.4, DirectX 12
4.3 cm x 18.5 cm x 13.5 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1033 MHz
Boost Clock
1111 MHz
Process Technology
28 nm
Max Resolution
4096 x 2160
4
API Supported
Ultra Durable 2, Gold plated HDMI, OC Guru II
Size
1 GB
GDDR5 SDRAM
Effective Clock Speed
5.4 GHz
Bus Width
128-bit
Required Power Supply
400 W
Additional Requirements
6 pin PCI Express power connector
Software Included
OC Guru ll
4.3 cm
18.5 cm
13.5 cm
Scroll to top
